:hyper::hyper::hyper: I KNEW IT!!!! I get 0 difference from summer to winter and you were still not getting 100% MPG gain and you finally did, I knew there had to still be more to why you weren't getting it all back. Also proves wind is not that big of factor on an empty truck (yes I barely see a difference no matter what the wind) and proves that cold air is GOOD. I love driving in 0F or colder temps because my truck is simply a bat out of hell. CAI (cold air intake (for those who don't know)) is not worthless (at least I don't think so). The efficiency calculation I found said the air has to be as cold as possible intake and as high as possible out the exhaust. This does not mean run your exhaust brake to get the exhaust hotter, it has to do it on it's own. So the only way to do it on it's own is to reduce the intake temps and rely on just the heat of combustion.
Done it again...
Mild weather 30-40*F, No wind, Cruise Set @ 55 MPH, IAT 140*F (Forced), Winter front (installed) 22 MPG on 40 mile round trip. :hyper:
I left today to get a couple gallons of paint for paint a room. So I headed to New Meadows, ID set my cruise for 55 MPH and took my time. On the way up canyon I was doubtful about numbers because I was watch 600-800*F EGT's but still 3-5 PSI boost. But once I made it ot the flats in Meadows Valley it fell 2-3 PSI of boost and floating 400-600*F. I was gain number rapidly. Once I hit New Meadows I had 16 MPG even after climbing the grade out. Now got my paint stopped in a friends place BS for a bit and came home set the cruise for 55 MPH home again. I'm all smileys because now I know the warmer air trapped under the hood is actually helping!
Right now I'm running a rheostat plugged into the IAT plug. This allows me to adjust and try to fine tune the IAT temps to get the most. So after yackin' with ISX and talking theories I went back up with temp to try 140*F IAt and this time added the winter fronts to feed warm air at the engine. So if your going to follow along with this you would lose your grid heater in the morning. But it throws no codes because the IAT temp is legit number so the ECM assumes its true. But basically if you want a toggle switch design you would build the ECT fooler basically but use IAT plugs on it then use the proper resistor for the temp you want... (Look back at the first few posts)
I think this is really great. I was thinking toggle switch, like everyone else. I had the same concerns about the added wires through the firewall but the relay is an interesting bump forward. Like someone reflected, too bad one must remember to switch back if one wants the grid heaters for starting. (In other words, "not wife friendly!" (Unfortunately, wife subscribes to the plan that what is mine is mine and what is yours is mine also. If you don't think so, start messing in her underwear drawer! LOL! Or better yet, try to use HER Subaru.) Back to the original topic, You guys are way more clever than I am these days... what about using the correct IAT sensor to trigger the intake grids... When the intake grids shut off, triggers the IAT fooler. If it picked up 1 mpg in cold weather, every guy would have to have one. You can sell them & we'll split the royalities and we can all move to a location where the grid heaters never run!Russ
I think this is really great. I was thinking toggle switch, like everyone else. I had the same concerns about the added wires through the firewall but the relay is an interesting bump forward. Like someone reflected, too bad one must remember to switch back if one wants the grid heaters for starting. (In other words, "not wife friendly!" (Unfortunately, wife subscribes to the plan that what is mine is mine and what is yours is mine also. If you don't think so, start messing in her underwear drawer! LOL! Or better yet, try to use HER Subaru.) Back to the original topic, You guys are way more clever than I am these days... what about using the correct IAT sensor to trigger the intake grids... When the intake grids shut off, triggers the IAT fooler. If it picked up 1 mpg in cold weather, every guy would have to have one. You can sell them & we'll split the royalities and we can all move to a location where the grid heaters never run! Russ
I think I know a way to make it completely automatic.. All you would have to do is install it. It would also fix another problem with the grids running on a warm engine. I am sure you noticed if it is cold out and you go to a drive-thru and shut the truck off, it will run the grids when you restart. The grids would run like normal any time the engine is cold.
So how are you going to do this? Sounds like a winner if you can make it work.
Now remember driving style is 80% of this number... So if you think it give you ability to be heavy on the throttle it doesn't... I'll get the ohm value off mine rheostat in the morning...
Mike, it doesnt seem to matter how I drive this thing I just cant get any kind of mileage.:cry: The best I ever got was 17.9 around Christmas and I dont know how it did it.
I am working on getting a tripple disk torque convertor and I think/hope that will help alot. I have 150hp injectors, edge comp, fass 150, 4 inch exhaust and slipping convertor. I usually run on 3x5 but lately have been running on 5x5 trying different things. I run 265/70/17 bfg street tread tires and 3.54 gears.
I double checked your tire size and your right on for stock size (off by 1 rev/mile 0.1%). As for the torque converter that might just be part of what's biting you. Other than that its all about driving habits... :shrug:Might try the fooler and see how it works out. Shoot! I didn't get the ohm reading... :doh:
Don't blow the brain up.
We all need the input!
hahahaha - no kidding
Don't think the 3x will help you much unless your slipping a lot now. Its a fluid coupling until lockup ..... so I think only adjusting the stator etc to a different stall will help slightly. Honestly ..... I'd try switchng out your injectors from 150 to stock .......... just to try ....... I would think it would be hard to control that.
Beyond that ..... smaller tires maybe ..... and you could try a different programmer ....... just for comparison - make sure your getting all the timing you want/need etc
But seriously ...... I'd look at the injectors as #1.
I just installed a 10k ohm potentiometer in the cab and ran wires out to the IAT plug. I have found the lowest I can fool the IAT is to only 77f with the 10k pot.. I should have went with a 20k pot. to get full temp range from -40 to + 300f. This will be a good start anyways. I won't have any hard data until the snow/salt is off the road, as I don't winter drive the truck, it's primarily my camper hauler. I'm excited to do some testing, it will be a long wait.
You don't want a colder temp, you want hotter. But you can only go to 200F, over that I think it throws a code. Ideally you want a 5K POT, as you will be able to dial in the temp easily. 10K is ok, 20k would be tough. Mike is using a 50K and can barely hit the temp he wants because the temp he is shooting for is in the 2K range which is very hard to hit on something with a 50K range, but something with a 5K range would make the 2K window much bigger and easier to hit. I don't know what the ohm for 200F would be, but I am thinking 1.5K.
I should have my fooler setup in a couple of weeks. Thanks to Mike I ordered a 12" IAT extension cable from Casper electronics. http://www.casperselectronics.com/store2/product_info.php?products_id=1503. Then I went to the local electronics store and found a double pole double throw miniature toggle, a 5K ohm potentiometer with knob., and a length of 3/c 18 AWG (0.824 MM2) type SVO cable. I am going to cut the + wire in the extension and connect it to one of the wires in the cable (white) and the other side of the cut wire in the extension to the second wire in the cable (green). Then connect the third wire in the cable (black) to the negative wire in the extension without cutting it. On the other end of the cable inside of the cab I will connect wire one (white) and three (black) to each of the two pols on one throw of the toggle (so I can use the IAT like normal). then on the toggle I will connect the + wire pole (white) of the normal throw to the first poll on the second (IAT fooler) throw (so one poll on each throw is connected to the + (white) wire). Then from the other poll of the second throw (green) I will connect to the potentiometer. The other connector of the pot will get connected to the third wire in the cable (black) that connects to the negative wire in the extension. With this setup I will have a T connector to connect to the IAT and the factory harness, A toggle in the cab to go between the IAT fooler and the normal IAT operation, and an adjustable potentiometer to set the IAT reading in fooler mode using my SG II IAT reading. I hope this will be a plug and play unit when I am done with it. When the extension comes in and I start to assemble this unit I will take pictures, make a wiring diagram, and keep a log so if anyone else wants to build one they can. Jim
