What oil filter do you use? Do you have a bypass? If you use more than one kind, list your preffered filter. Trying to see what's the most common. If you use a Stratpore LF3894 just select the LF16035. If you use a Hastings LF608 just select Baldwin BT7349. Here is the data I have on the filters listed. Donaldson P558615 40um @ 98.7%, 20 @ 50% Cellulose
Fleetguard LF3972 30um @ 95% (35 @ 98.7% last info) Cellulose
Wix 57620 30um @ 95%, 20um @ 50% Cellulose
Wix 57620XE 25um @ 95%, 14um @ 50% Glass Enhanced Cellulose
Baldwin BT7349 30um @ 98.7%, 12um @ 50% Synthetic blend
Fleetguard LF16035 30um @ 100% (25um @ 98.7% last info) Stratapore Synthetic
Purolator L45335 20um @ 97.5% Cellulose
Purolator PL45335 20um @ 99.9% Synthetic
Amsoil EaO80 20um @ 100%, 15um @ 98.7%, 7um @ 59.97% Nanofiber Synthetic
Donaldson ELF7349/DBL7349 20um @ 100%, 15um @ 98.7%, 7um @ 59.97% Nanofiber Synthetic
Mobil 1 M1403 10um @ 50% Synthetic blend
Edited by AH64ID
  • Replies 53
  • Views 21.3k
What oil filter do you use? 72 members have voted
  1. 1. What oil filter do you use?
    • Amsoil EaO80 or Donaldson ELF7349
      13
    • Fleetguard LF16035 (Stratapore)
      15
    • Fleetguard LF3972 (OEM)
      14
    • Baldwin BT7349
      8
    • Wix 57620 (NAPA 7620)
      4
    • Wix 57620XE (NAPA 7620XE)
      4
    • Purolator PureOne
      4
    • Donaldson P558615
      1
    • Mobil 1
      2
    • I use a bypass too!
      9
Please sign in or register to vote in this poll.
Ok. Well I just received my oil report from black stone labs and they told me I can now run up to 9k miles between. That test was on a mopar filter and shell rotella 15-40. Since then I have went to the stratapore and shell synthetic 10-30.
Be sure to do an OEM sample interval with the new oil.. All oils are different. Have you done a UOA with 15w-40? I ran HDD 5w-30 for a OCI and got better wear with the AME 15w-40.
Yeah I need to buy a drain petcock so I can easily do UOA's. I will probably just do this oil change at 7k again.
  • 3 weeks later...
:cool:
I usually use fleetguard but last time I went to the cummins store he had Donaldson for $5.50 each so I got a couple of them.
What a deal!
The 92 gets Baldwins (Now) Napa Gold/Wix (in the past) and has a Frantz Bypass99 Gets Baldwins (Now) Napa Gold/Wix (in the past)
  • 3 weeks later...
I've always used the Stratapore but they're getting very expensive. Not so much an issue lately since I rarely drive the Cummins anymore for economic reasons but it still doesnt make it any cheaper when I need one. Thought about Geno's but after shipping costs they're more money. Last time I bought one from Cummins West they were going to charge me around $17 but I said thats to expensive and I couldnt justify spending that kinda money for one oil filter. So they reduced it to just under $15..... Not sure what NAPA charges but I believe their filters are WIX. I also have a place that sells Donaldson too but I'm not even sure what they'll want either.
BF web express has the the Baldwin BT7349 for $4.79 each plus shipping if you buy them by the case. http://www.bfwebexpress.com/catalog.asp
Hey I manage a NAPA and we have our new platinum oil filter #47620 is on sale this month for $8.04 and I don't know a whole lot about this filter because they are brand new but my filter rep said they are the same as the amsoil filtes because wix makes alot of amsoils filters. Good Luck:thumb1:
  • 3 weeks later...
Just switched over to the Baldwin BD7317 this last week when I did the oil change and services on the wife's truck. Oil pressure and all looks good so far. :thumb1:I'll be keeing an eye on the cleanliness of the oil as compared to the BT7349 I have been using in the past.
It's really amazing how clean the oil stays in a Cummins diesel. I've had 2 Kubota's, Fjord 6.9 & the oil is/was black as soon as I changed it & pulled the stick on recheck oil level. Still on my second Kubota, what a trooper, the Fjord I couldn't keep it on the road.
The Cummins is more like a gasser, stays clean for at least 500-1,000K, even before I put the Frantz by-bass filter in.
Dave
BTW, how often should I change the main filter? I change the Frantz's TP every 2-3K.
Honestly I really don't put much thought into it if it isn't a Fram. I have had bad experiences with Fram left and right and wouldn't dare use one on my Ram. Honestly though I have used the Mopar (stocked at Wally World), Fleetguard, Napa, Purolator, etc. I remember reading a page somewhere that showed where this guy dissected 30 oil filters and there were only like 5 manufactures, most of them were just relabeled and repriced.I have thought about a bypass system but I am not so sure it will pay for itself since I change my oil in the normal service interval anyway.
Some guys on here have gone 80K w/ oil analysis using a bypass. That would be worth it.Dave
Some guys on here have gone 80K w/ oil analysis using a bypass. That would be worth it. Dave
I would never trust running oil for 80k miles. In fact anything past 10k is just to much for me to stomach when oil is relatively cheap.
From what I've read, oil only gets bad when it's dirty.
There are 2 things that effect oil life, contamination and acidity. Contamination is what normally ends an oil's life as the oil and filter just can't hold any more; but with proper filtration you can run an oil longer until you get to where the acidity has depleted the TBN number and the oil needs to be changed.
Thats pretty much right on. Amongst common belief, oil never looses its lubricating properties unless its burnt. Its all the crap that gets in the oil which is the reason we need to change it. Thats why tranny and differential lube lasts so long, because there's no combustion contamination.
Or oil in a turbine engine.. lats indefinitely.
