Bulk Oil Buying... Transfer pumps for Crankcase oil
I'm able to buy the original CI-4 oil without any CJ-4 oil additives or lack of them for my 2 older diesels:thumbup2: :hyper:However, I don't like standing on a ladder holding a 5 gallon bucket over my engine with a giant funnel. It won't work. :doh:So what oil transfer pumps you guys got or use? Or better yet, what are some of the tricks you guys do with bulk containers?TIA
  • Replies 14
  • Views 2.5k
Get a 1 gallon jug and pour a gallon into it from the 5 gallon bucket while you are on the ground. Otherwise, I would just get a manual pump from mccmaster carr.
I use 1 gal jugs. Do you want my old ones? They are valvoline pre blue 1 gal jugs.
Where are you both getting it from if you dont mind me asking
And what is so special about it?
What does 5 gal cost. I can get 1 gal for 10.00 when it is on sale. That is valvoline premium blue 15/40
That's about $15 a gallon. Do you mix it all together and use it for every thing?:lmao2:
Thanks everyone.... it made a mess for a short while till tilted up higher. Hate that :banghead:.Oh boy did my 12 valve ever thank me tonight for that non CJ OIL. Sounds lots smoother.I paid 68 bucks for each 5 gallon bucket at TARR OIL in Portland, Oregon.I'm going for a pump of some sort to make it easy. However, I did find rubber hose about the right size to screw onto the threads that the cap screws to, just like a gas can spout, didn't leak after that.Thanks for the tip for a transfer pump.Dripley, that oil's so good I put it in my wifes car after I'm done with it:lmao:
  • 4 weeks later...
Heres what I call bulk oil buying, two 2500gallon tanks of Mobil oil, one 5w30 for all the gasoline powered trucks at work, and Mobil Delvac 1600 15w40 for all the diesels.
-Jordan-
