Alternator is done. Time to replace. You can rebuild it yourself but make sure to get both diodes and brush kit. There are other kits cheaper than LarryB as well. I will admit his diode packs are expensive. Make sure to get rid of all tin foil and wiring mods.
  • 2 months later...
Hey guys.  So I am on my third alternator from Oreilly's...fortunately they have just been swapping them out on warranty when I explain the problem.  I am looking into a local shop that can build the diodes for me, but would be interested in the contact info or nudge in the right direction for purchase through sources you guys have had success with (LarryB etc.)
The odd part about this last time the problem came up is that it had only been about two months since I swapped it, and when I popped the hood to pull the fuse both battery terminals were covered in corrosion, and after pulling the fuse, the lock up issue continued to happen.  I came home that day, put new connectors on all for terminals, cleaned everything really good, and ran the truck with no alt. fuse, and problem disappeared.
Is there possibly something else going on in addition to the alternator?  A coworker suggested an open ground might be aiding in the failing alt.  I really don't understand vehicle electrical systems, so any help or advice would be greatly appreciated.
Here is your master ground for the PCM, ECM and VP44...
This points out the added requirement of keeping the battery terminal clean and in good condition. There is no computers have grounds that bolt directly to the body. Only secondary systems like lights and other minor equipment will. Don't bother chasing grounds everywhere...
Just now, dripley said:
My PCM has a flat insulated wire that goes from one of the mounting bolts to the firewall just above the turbo. I always considered that a ground and I did not add it. :think:???
That is not a circuit ground. The PCM is mounted on plastic fasteners in the bracket so to get the case a ground plane again that strap was added in hopes of noise shielding. That ground strap has nothing to do with circuit wise ground. Even my truck has the same strap as well.
Here is the PCM circuit grounds. Take note to Connector 1 and pins 31 and 32 going to Ground G115.
Thanks clearing that one up Mike. Always wondered about that wire. I do see the circuit grounds you are speaking of.
  • 4 weeks later...
So i have combated this issue for the past 3 years. I have four second gen trucks for my company and 4/4 had the torque lock up issue. I have tried many fixes that were merely bandaids for a few weeks or months but it then came back. I have tried so many of the tips and tricks. Spent countless hours looking for answers and just a few months ago I tried the dumbest thing. It cost me less than 10$ and i haven't had a hick up. I didn't unhook any batteries. It was happening that same day. I just made some
modifications  and when i went for a drive it was gone. it has been over a month with out a hick up. Ive done it to 3/4 since one truck is out of commission. I just talked to a friend who's second gen had started doing it again this week it is driving him crazy. I sent him so photos and i got a text back an hour later. I had been doing it today and once he did what i told him it was gone. Are there still a lot of you fighting this issue right now??
It makes us all scratch our heads as to your intentions when you make a post like that.
We have a lot of trial and error pointing to bad alternators causing %99 of the lockup issues in 2nd gen trucks.  From what we have seen in the past there is no $10 fix that resolves the root issue of burnt out diodes in the Alternator.
We are all ears, but you will have to let us know what you found to work.   You will find that we are pretty close knit group so we like to see info spread rather than hid.
Guys, took my alternator in to Napa, AC was 0.9 but their tester said it was good!!!! WHAT GIVES? is that even possible? 0.9!?
4 hours ago, notlimah said:
AFAIK NAPAs test isn't checking for ac noise specifically and its checking it under full load, so you'll get different results.
So 0.9 vac is ok? I took it to oreillys after and they came up with Ripple... .39
damn. Cant believe how difficult this electric stuff is.
