November 22, 201213 yr NV4500So I am driving about 50mph with my foot light on the accelerator and she just eased out no grinding no pop. What the heck?:spend::spend::spend:Here we go again
November 22, 201213 yr Owner Intermal trans problem. Bearing or something. I would check the fluid and see if there is metal in the oil. Side note. I've see this in a older military 2 1/2 ton truck. It will push the stick out of gear forcefully even if you your pushing the stick to the dash it would force it out as soon as you release the power. As for cause we never fixed it but got rid of the old fire truck. (Sorry).
November 23, 201213 yr NV4500 So I am driving about 50mph with my foot light on the accelerator and she just eased out no grinding no pop. What the heck? :spend::spend: Here we go again Could it be the infamous 5th gear nut issue?
November 23, 201213 yr Author When I bought it 4-5 years ago it still had recipt in glove box where he had it in the shop. Recipt said 12 month warranty, it also said something about repair kit. So hopefully they didnt weld it on.I think it was done at Amco Trans.So far it has not done it again, I plan on draining fluid Sunday. Saturday I got to pull head off my John Deere 4030, it blew a gasket awhile back, I just hope the cylinder wall aint washed out, it been blowing a little blue smoke for a year or so. :whistle:Who rebuilds NV4500'S? And how much are we talking about?
November 24, 201213 yr I believe with the 5th gear nut issue you loose 5th all together. My old 5600 started slipping out of 6th while coasting. Then later on it stated doing it in 1st and reverse, but always coasting not under any engine load. Then one happy day I lost 4th altogether.
November 26, 201213 yr I've had my old 4500 do it once or twice.. usually when transitioning from on/off throttle.. I think it was attributed to my just not fully seating the shifter.
November 26, 201213 yr Blumenthal out of Oklahoma City rebuilds or sells rebuilt units but they ain't cheap. I saw a seller on eBay that had them for $1000 a few months ago.
:spend:
