- Replies 24
- Views 6.3k
dripley 7 posts
98whitelightnin 3 posts
mopartechnician 3 posts
fire176969 2 posts
I have some oil leaks in some usual places such as the tappet cover, vacuum pump, and maybe the front cover and /or the front main seal. The other day I noticed some oil coming around from the rear of the engine. I thought it was from the valve cover but upon further inspection it appears that it is coming from between the head and the block. I looked at it with a mirror and can see the joint between the two has a wet oily line. the oil is migrating down and onto the block. About 4 months ago I blew my radiator climbing the mountain and briefly overheated the engine(my fault), could this be a by product of the incident and I almost blew my head gasket or could there be a simpler explanation? No coolant in the oil and no oil in the coolant.
