Hi everyone, I have read alot of posts here and on CF trying to put together the "best" mods to my truck that I think fit my needs. Before I pull the trigger I want to run it by you and make sure I am headed in the right direction. My truck is a 2000 3500 Dually two wheel drive with an automatic tranny. It has 173,xxx miles on it. Previous owner put 65 horse injectors in it, plugged the wastegate, K&N air filter, 4 inch exhaust turbo back,and a new stock lift pump. I've read these trucks will go for 700,000 + and I'm going to have to try because I can't afford a newer model! Besides the occasional trip around town I put a 4K pound Lance 11'6" truck bed camper in the back and pull a tandem axle car trailer with my 69 Bronco rockcrawler on the back. I don't have a ton of coin to drop. I don't want to smoke the back wheels off the truck, hook up to a sled or smoke out three lanes of traffic when I blow by in the passing lane. (on occasion smoking out a ricer is nice I have to admit!) I essentially want a dependable, easy to maintain, Keep it simple, drive across country kinda rig. Here's what I plan: Install the fuel pressure gauge I bought Continue running the TCW 2 stroke oil (thanks moparman!)Install a Raptor 150 Vulcan big line kit to VP pumpRun Baldwin PF7977 fuel filter Put a boost elbow onGet my other gauges; pyro, tranny and boostPut some coolvue mirrors on so I can see what the heck is going on behind me Airbags in the rear BHAFAnd beef up the tranny, torque convertor, shift kit, whatever else needs to be done. Other than that I just want to be able to run it and fix the other "stuff" that we all know comes up. Like my leaky roof above the overhead monitor and the passenger window that sloooooooowly goes up. Thanks and looking forward to what you have to say.
Looks like you got the plan all put together pretty air tight other than the one thing that stands out to me is the Balwin fuel filter...............I would run fleetgaurd ,Hastings or wix or pretty much anything but baldwin, I have had many many filter courses over the years as a Diesel Tech and Baldwins are just a small step above fram in the filter world.:2cents:
don't play with the waste gate until you have a fooler of some kind...i put a "edge boost elbow" on my stock 99...works great at low rpms, with little power. then i was pulling a trailer uphill in 4th gear(i got a stick) and boom...no power! cars and semis were trying to pass my like i was pan handing!
With this previous history I would throw the K&N out... Then do a turbo inspection and check the air tubes for dust, dirt, and oil... As for lasting a long time I've got 2 member here one at 600K miles (92 Dodge) and another with nearly 800K miles (01 Dodge)
Here's what I plan:
Airbags in the rear
BHAF
Other than that it looks like you covering the bases properly. Take your time and do your research on your part and mods... :cool:
He has a BHAF on the to do list there Mike. :thumb1:
Yeah I caught that that's why I went back and added that he should check the turbo and air ducting... I figures might as well double check everything since K&N has a bad history of dusting and collecting oil in the air system... I rather be safe than sorry...:rolleyes:
Several years ago I had an ATS torque converter in a turbo 400 with a 500 big block. This was before ATS was really known and was in Wheatridge Colorado on 58th and Wadsworth. Clint really knows his stuff but it cost $$. If you have the means, I would go with ATS.
Cool Thanks!
If the list is random, having a BHAF on the list is good. If it is ordered, I'd move the BHAF and inspection of the intake and spinny thing to the top.
Checked the tube from the air box and surprisingly it was clean. Ordering the BHAF now. On the tranny, when the time comes, I decided to go with Goerand. Customer service was top notch and answered my questions without trying to sell me a brand new transmission.
Good choice.............I have heard of way too many horror stories about ATS and their lack of post sale customer service since they have grown to a large company.
