Tips to pass diesel emissions
- Replies 12
- Views 11.1k
Mopar1973Man 4 posts
JAG1 2 posts
TFaoro 1 post
cbrew 1 post
Yet another topic that needs to be written up into an article for those of us unlucky enough to have emissions tests. please add any tips or correct anything I put in.
Up until this point I have had a pretty much stock truck. I turned the box off and passed without issues. In el paso county Colorado Springs we are required to pass a couple of tests.
Snap test at 35mph and 55mph I think with opacity of %30 or less. ( what does %30 opacity actually look like)
A snap test means that the person will go from idle to %100 throttle and watch for smoke output.
What I wanted to do is put together some things you can do to help pass with your diesel. in my case a 24v with 100 hp injectors, quadzilla adr, and a he351ve. My setup should pass without much issue provided I turn the tuner off, however some guys might not be able to pass.
Lets start with the basics
-tuner off
-Smarty that can do half power mode.
-throw oem injectors in
-Fix any boost tests
-ensure your map isn't stuck reading high
-run no additives, no 2 stroke.
-new air filter
-ensure that the truck is up to temp.
Beyond the basics,
So lets start with timing, Does timing tuner levels help or hurt smoke levels when talking about passing emissions?
Another thought I had was to disabled TC lockup to help pass emissions if they do a snap test on the dyno. This would decrease spool time, decrease load, and thus decrease smoke.
In conjuction with that depending on how they do the emissions tests you could disabled OD, which depending on the speed they do snap tests would keep rpms up rather than having to deal with the low rpm load found at 45-55 mph while in OD.
If you wanted to get pretty technical you could install a voltage clamp on the map sensor wire, to 5ish psi, to limit the boost the ecm is going to see, thus limiting the fuel the ecm will depend.
Thoughts?
