Black smoke, no RPM, new injectors needed?
- Replies 15
- Views 2.8k
rburks 4 posts
Mopar1973Man 3 posts
GSX455 2 posts
CUMMINSDIESELPWR 1 post
So, the truck runs, but not great. I get the puff of black smoke when it first starts, but under acceleration, I start seeing big black smoke I've not seen before. the truck is stock, with the exception of an Airdog 150, and has about 340k miles. the injector are stock, and I've lost power recently.
I'm not sure if the power loss is due to the injectors being worn, or the fact that my RPM will go to zero, and the pump misses, like an ECU connection issue. when the RPM gauge is working, the truck has power, when the RPM gauge goes to zero, and hard acceleration makes it almost roll coal, with no power.
I'm hoping that its a bad connection at the ECU which puts the VP44 in some limp mode, the only DTC using an INNOVA 3100 scanner, was a P0341 code, which I cleared.
Thanks for any help,
GSX455
