- Replies 21
 - Views 16.5k
								dave110 3 posts
								99rcummins 3 posts
								joecool911 2 posts
								Me78569 2 posts
I have a 99 Cummins with 109,955 miles on it. I have noticed I had white smoke coming out of the blow by tube but not anything noticeable unless im stopped for a few minutes. if I take the oil cap off it blows a little white out of it but not like clouds of it. So next I did the oil cap test and removed it and flipped it upside down and it didn't bounce around or move (except a little due to vibrations of the engine). the truck runs awesome no lack in power perfect pick up and go, it doesn't smoke except a little black on start up and doesn't eat coolant or oil. No knocking either. The oil pressure is around 30-35 at idle and at normal cruising speeds of 55mph at around 1800 rpm its around 40-42 and the temp never rises above 192. my question is, is this normal im new to Cummins and should I worry
