New BHAF options!
I currently am working with a manufacturer to have an additional BHAF filter option. This filter uses Donaldson's Powercore technology and has a capable flow rate of 1300 CFM while filtering the air down to a micron rating substantially better than stock.
I am currently in process doing heat soak and IAT temp checks and EGT checks at WOT runs, cruising, part throttle acceleration and transient boost speed from cruising to passing acceleration.
Next tank of diesel will be a fuel economy test to see if any improvement exists.
I will do my best to keep everyone up to speed.
  • Replies 201
  • Views 41.8k
  • I have seen several dealerships void warranty for anything aftermarket. That said a K&N WILL VOID POWERTRAIN WARRANTY. Seen this more than a few times. If and when I do buy a new vehicle I will pu
  • The problem is not just buckling, but sealing properly.  A small chunk of 4" exhaust pipe on the inside of the flange is the definition of "cheap insurance". An old tim
  • It's for guys like me that are always barely out of idle.
Air Filter Poll 26 members have voted
  1. 1. What would you use?
    • BHAF
      84%
      22
    • New airbox for new filter
      0%
      0
    • Full air box kit and filter
      15%
      4
Please sign in or register to vote in this poll.
When you get done collecting data, mabe you can summarize it all in a post, and we can make it into an article!
Going to try.
Okay folks I've been slammed with work recently so forgive me for not going through and making a huge post of accumulated data and info. I will try to do that over the weekend.
Update now. I've gone and reinstalled the factory air box and found the biggest difference is temperature of lower boost to no boost region. Won't say which is cooler so here is your cliff hanger. If I'm lucky I will try and get some dyno time next month to test both back to back and see my baselines.
  • 4 weeks later...
I recently replaced my BHAF with one of the Volant #61504 filters and Volant #51921 pre filters on my 2002. No cold air box, just mounted on end of turbo hose. I did make a heat wrap out of some Thermo Tec FR insulating mat I had laying around. I haven't done any towing or heavy duty use to see if EGT's dropped any. It does seem like the engine revs a bit easier and a bit more turbo sound. My BHAF (WIX2790) had been on for several years, so may have plugged up a bit. I may possibly be back to normal.
Good to hear. Remember you can back flush the air filter to knock out the large debris on the Volant/Donaldson Power Core filters. Just be sure to use low pressure air no more than 10 PSI if memory serves me right.
Edited by Vais01
I just picked up the Volant 61504 myself!  Did you by any change put anything inside the ending of the flange (on the filter) to avoid not getting a perfect seal when tightening down the clamp? I was thinking a PVC coupling or pipe cut to size.  Seems as if the seal buckles in depending how tight/loose you make your clamp, maybe it's just me?  If anyone reads this who runs the normal Donaldson/Fleetguard/Napa BHAF do you do something similar as I stated above to ensure the seal will not buckle and cause a leak?
Welcome to forum.
I use the BAHF and just clamp them together as is. It has not buckled and holds together tightly. Some here do use different things like you are mentioning. If mine buckled somewhere I would definitely be adding something.
An old timer on the forums realized that everyone needing an unexpected premature engine rebuild was running a BHAF.  He attributed it to the filters filtering ability, but more digging and testing by other members shows that the problem is likely the flange sealing/buckling.
Edited by Cowboy
Yep, you absolutely need something stiff inside to give you the ability to clamp the filter on.
Yep, that doesn't surprise me at all.  Luckily I have to make several cuts on my new exhaust system so I'll have some 4" scraps laying around! :thumbup2:.  I must say that I'm very pleased with the quality of the filter itself. Volant scored big time on being able to work with Donaldson.  I picked mine up for $76; they are $99.58 directly from Volant.
Where did you buy it?
No, though I have put some thought into it.  With my current system, a 4.5" or 5" filter would work best.
With this one being so small, I could make a cold air intake for it... IDK
I have been thinking about trying one just to try something different. I dont know anything about them other that what I have read in this thread.
Just took the truck out for the first drive of the year.  Filter fits excellent in the space given.  You can angle it right at the port where cold air comes in if you desire! Kind of hard to see, but in the one photo it contacts right on the plastic lip of the filter and the rubber end on the factory stud.  Filter touches nothing else!  I'll be keeping an eye on the rubber end for wear.  I stuck a camera in there for a 30 minute drive and it didn't move an inch.  The sound is awesome if you have your silencer ring out.  It's not overpowering either...the turbo whine.  Just the right amount.  However, last time I drove my truck it had a stock exhaust and intake so everything is sounding awesome right now. This morning, I just finished putting in this little guy and my 4" exhaust with an FTE Resonator (Highly Recommend! No Drone!)  Nice to catch a wonderful day here in Wisconsin with 52 degrees.
Edited by sooxies
That answers my thoughts on how it would fit on the fender well. I made me a cradle for the BHAF to sit it and that one wont quite get to it. I would have to make something different for that. Thanks for the photo.
How deep are the pleats? Sure doesn't look like anywhere near enough filter at first glance.
