Vibration
Hello all... I was invited by Tyler to come hang out here. He said there was a great bunch of people here. Is this true??? ;-)
Anyway.. Being such a newbie.. I'm not sure if I'm being paranoid. Hopefully I can explain this correctly. When I bought the truck about 6 weeks I could feel a little vibration in the steering wheel and both pedals. I attributed it to the motor and figured it was normal being a diesel. Well.. recently it seems to me to be a little more pronounced where it seems to be resonating thoughout the cab.. It happens at idle and driving any speed. It's a very fast vibration and it kind of gives a tingly feeling to my hands and foot. Does anyone know what I'm talking about? Thanks!
Edited by dodgedieselnewbie
  • Replies 53
  • Views 8.5k
  • Tom, Welcome to the forum!  Diagnosing a vibration can be fun! (throwing hammers through windows fun)  It appears that you notice this vibration even at idle and in park. (you need to verify this
    Yeah its true... One big family of Cummins owners.
  • There is a bushing in the tail shaft of the transfer case.  This is pretty important, and is often overlooked.  It allows the yoke to "rattle" (for lack of a better term) on the output shaft.  I have
Welcome! ABS pulsing? Does it stop smooth? Idk just throwing it out there.
LOL.. you guys are presenting ??? to me. I'm the newbie. How do I check flex plate or damper? Rear ABS... Yes.. it stops smooth but seems like all my braking is done up front. I don't think pulsing would describe it.. hand tingling vibration is accurate and I can feel it in my foot. It might me a little more pronounced during turns..
I just went out and checked again.. in park at idle it's subtle.. accelerating more pronounced. Maybe I'm being paranoid?
The damper (harmonic balancer) is the lowest pulley on the engine right on the end of the crankshaft. You'll see a thin rubber ring that runs around it about an inch from the outside of the pulley. Make sure the rubber isn't squished out or deteriating. It's normal for it to stick out just past flush.
Okay.. checked damper. Looks okay based on what you said.. yes?
Flex plate? Can that be felt in park and giving it a little rpms? This past weekend I did an 800 mile round trip with my camper (8500#) and a couple of times when I tried to kick it down a gear by giving it heavy acceleration.. it kicked in out of gear hard.. related?
On the front of the damper there is 2 tick marks and you need to check and see if the two tick marks are still lined up.
Auto. Hmm... As for the shifting that I'll leave to "Dynamic" he's the site tranny guru. Might as him about the shift issue and the flex plate.
I went out to look.. can't find tick marks.  Are they indentations or marks?
Whats wrong with you guys??? The man just bought his first Cummins. That's where the tingly feeling comes from. That's the same thing I felt back in October of 01 when I drove off the dealers lot. It is normal!!!
All kidding aside, Tom, it may be as you describe, a little paranoia and can't add anything to the other suggestions members have offered. So welcome and we will help as much as possible. Sounds like you have a pretty good ride to me.
I hope it is paranoia.. I'd like to get together with someone who has had one for a good while to give mine a look and feel to set my mind at ease.. lol. The more I read about problems.. the more I look for. Yikes...
Mine shakes and clunky so bad that yours prob feels like a caddy
I never gave it much of a thought for the first 250k, it's the last 110 that keeps me wondering about anything I hear or feel that's seems "odd". Just clicked over 360k this morning!!!
Mike and I are in a race to see who gets back from the moon first. I am way in the lead as long as me or the truck dont give up first.The only way the truck will give up is if everything surrounding the Cummis falls apart.
Tom,
Welcome to the forum!  Diagnosing a vibration can be fun! (throwing hammers through windows fun)  It appears that you notice this vibration even at idle and in park. (you need to verify this.  Big difference on what to check.)  Your harmonic balancer looks ok in the picture.
If you notice it sitting still, that narrows it to a rotational vibration (anything on the crankshaft) or the vibration isolators (the motor mounts, transmission/transfer case mount)
I would check the trans/transfer case mount first, as you also noticed a funny shift.  (I use a jack and jack the trans up.  The trans should move with the mount, not relative to it.
Motor mounts are harder to check, but you have a friend watch the motor move as you have it in drive (or reverse) with brakes fully applied.
HTH
Hag
