Time to kill some rust!
- Replies 19
- Views 6.9k
The_Hammer 9 posts
Buzzinhalfdozen 3 posts
Mopar1973Man 2 posts
IBMobile 2 posts
It looks interesting. They have everything for a DIY guy. I like that its tint able with colors like " jungle love" "don't yell at me", and "blood bath". I wish I'd known about the Chassis Saver™ whe
That's all I every do is either park over a sprinkler or get out the power washer...
I like doing things myself, but also money is tight so I HAVE to do most things myself. I do all my own mechanic work, carpentry, plumbing, electrical, welding/fabricating, you name it. I've also lear
My truck had a plastic drop-in bedliner when I bought it and knowing they are nothing but a rust factory I promptly removed it. After removing the liner I found a decent amount of lighter rust with a couple of heavier spots with some pinholes. I cleaned it up and hit it with some rustoleum until I could take care of it properly. I ended up putting in a rubber mat to keep coolers and other gear from sliding around in the bed and normally took it out once a week to make sure the bed was dry underneath. Well, I got busy and stopped taking the mat out of bed and ended up with this.
I'm going to hit the rusted areas with a wire wheel until they're bright and shiny and then seal it up. Not sure what paint I'm going to use yet, I definitely want something rust inhibiting though.
