Starter Bolt missing, stranded with loose starter
- Replies 14
- Views 10.4k
Ed's5.9 4 posts
IBMobile 3 posts
Me78569 2 posts
Mopar1973Man 1 post
no only 1bolt was left and it was lose, also it's not the factory bolt (hex instead of 12pt) so I'm not sure if they backed out because they where not long enough to grab enough thread the shop where
from what I can see the bolts are the same for 94-11
I ended up buying the factory bolts from cummins, pulled the starter, generously sprayed holes with brake cleaner, hit it with some air and used a small caliper to get confirmed hole depths. Once I ha
Does anyone have the bolt specs for the 3 starter bolts on a 2004 Ram 2500 5.9l 24v I have found the part number (04429834) but I need size, thread, pitch and grade to find a quick match at fastener store, thank you !
