Ball joints
Well half way through my trip up north I have found that my Balls joints are loose again.
The moogs lasted 20K
The Danas lasted about 15k
Not really sure what to do.  I would love to just get something that lasted from the factory, but I dunno.
Thoughts on what to try?  Should I do the dana ones again?
  • Replies 127
  • Views 28.4k
  • The ball joints in te 00-02 fit in the axle yokes and not the knuckle. They also don line up with each other. http://www.cumminsforum.com/forum/98-5-02-non-powertrain/475650-interesting-info-about-00-
  • This is how my dad taught me to do it.  Jack the vehicle up making certain that it's level.  Find the middle of the tire and make a mark. Using a piece of chalk or greese stick h
  • I ordered these from RockAuto, they are in fact relabeled Raybestos Professional joints. The boxes are labeled "Made in Taiwan" but the joints seem to be high quality and don't have that typical "chea
Little information to make you think. The lower joint is a actual BALL Joint with a ball on the end of the taper. The upper is not a BALL joint but a SHAFT joint. The upper has a long rod like shaft into the cup.
1 hour ago, JAG1 said:
Other thought...... if the BJ's are really good then you worry about the bj socket or cup wearing.
This makes me think about getting the greasable ones.
my oe's were sealed and lasted 200k+ miles. wish i could find some more of those. Installing them is a pretty involved job, but picking which ones to use sucks.
Trying to pick which ones to use is a royal pita. I need to figure something out quick though.
I think about the actual manufacturer. Wonder who they really are as all the brand label companies can subcontract to the different forges to be made. Then wonder who actually specifies the better metallurgical alloy.
Dave, my oems only lasted 65 k miles.
@Mopar1973Man
It looks like most of the upper ball joints NAPA has are splined. Hell, the ones in the truck now may be splined, I seriously doubt they're stock with 300k miles on them.
Keep in mind this is an advertisement for Raybestos so they are definitely going to make their products sound awesome. With that said it seems like they make quality parts and they say their warranty covers the replacement part PLUS labor. I'm going to give them a shot and see how it goes.
Jag, I know what you are saying. I am still trying to find a set of tires I can get 89k to 90k miles out of.
i
Edited by dripley
Mine had 29,000 on them when I bought the truck they were tight. So to be honest with you guys, the added 35,000 miles was mostly carrying a fully loaded truck camper around 3400 lbs fully loaded. But still seems premature to only last 64 k miles for oems on the 2002.
Source auto told me Spicer has met market demands by making two grades; affordable ones made in China and then the expensive USA made which last longer. They put in the USA made for me $1400 bucks w new tie rod ends and so far they are holding with no play in them.
I have seen the Spicer affordable grade but not the USA made. Do you happen to have a link to them?
Also I was looking around at ball joints again today. It would appear that McQuay Norris, and Raybestos fell under the same brand a while back. I also heard some where a good while back that Moog had fallen under the Federal Mogul umbrella. Then I saw this and it would appear that they all are under the FM umbrella. http://americanmachinist.com/news/federal-mogul-takes-over-affinia-chassis-components How do you know what you are getting from anyone anymore.
i
Changing ball joints isn't a fun job and a few more bucks now may be work fewer R&R's down the road.
I bought the dynatrac's and they are a very nice unit, hopefully they last. I have 30K miles on them now and no issues.
i
There's no real way to know what the hell your buying anymore.
I'd try the Dynatrac ball joints but I can't drop $550 on them right now.
There is plenty of truth in you get what you pay for. Search the bigger forums on cheap ball joints.
Dave Ripley, I don't have any information on those. I'm just repeating what the owner down at Source automotive told me about the better USA made Spicers. They do BJ's all the time and would have to guess that this has been their experience with them. I would call them for a line on getting them. Source Automotive 503 654-9004. Rip Rook is his name. Rip is his nick name and Rook is his real last name. I used his dad many years ago for legal advice, a very good attorney back in the day.
:wtf:
Dude... I couldn't even do that... :omg:
Part of that post is missing :doh:
I would try them if they lasted significantly longer than what's currently available and I could afford $500 for them. According to CF I'd still be a cheap a$$ because I didn't spend $1000+ on Carli joints lol.
I'm still going to try the Raybestos Pro joints, I've heard a lot of good things about their parts.
I dont think Dynatrac even makes them for the 00-02. Even so at near $600 that is out of me league. If i knew for a fact they would last 150k+ I would think about.it.
Thanks for the info Jag. I keep hearing about the more expensive ones but cant seem to find the.  Rip Rook, you gotta love name.
If he has anything good to say about ball joints let me know.
500 is too much for ball joints, just can't imagine spending that, let alone 1000.
Would $500 be too much if you knew for a fact you would get 200k miles out of them?
Maybe, but would have to see some folks getting that kind of mileage. The bad thing is by the time they do who says they might have changed the design. My oe went 200k but others have not. Even some of the spicer adds say it is the oe joint, but they have grease fittings and I dont remember my oe having grease fittings. i think maybe original manufacturer but not the exact part.
