Ball joints
Well half way through my trip up north I have found that my Balls joints are loose again.
The moogs lasted 20K
The Danas lasted about 15k
Not really sure what to do.  I would love to just get something that lasted from the factory, but I dunno.
Thoughts on what to try?  Should I do the dana ones again?
  • Replies 127
  • Views 30.8k
  • The ball joints in te 00-02 fit in the axle yokes and not the knuckle. They also don line up with each other. http://www.cumminsforum.com/forum/98-5-02-non-powertrain/475650-interesting-info-about-00-
  • This is how my dad taught me to do it.  Jack the vehicle up making certain that it's level.  Find the middle of the tire and make a mark. Using a piece of chalk or greese stick h
  • I ordered these from RockAuto, they are in fact relabeled Raybestos Professional joints. The boxes are labeled "Made in Taiwan" but the joints seem to be high quality and don't have that typical "chea
Checked some more part numbers and AC Delco Professional is in fact rebranded Raybestos Professional parts. I checked the 98-99 HD steering parts between the two and like the ball joints they're exactly the same. Just thought this might be useful information to share.
2 hours ago, Me78569 said:
Anyone have a 98---00 truck with the t steering?
I need to do a nitty gritty alighnment and could use the measurement from a good truck.  Can anyone measure the distance between the hubs from the knuckle joint shalf to knuckle joint shaft on the tie rods?
I'll have my truck in the garage tmw if you can wait. I'd go check now but it's cold and snowy.
Yea no worries tomorrow will be fine.  That'll be a huge help.
Thanks!  Hopefully you understand what I am asking for haha.
Hmmm I could use a definition of knuckle joint shaft. Just center to center on the tie rods?
What about calling a GOOD front end shop? Maybe they can source longer lasting ball joints? John's Alignment in Portland Oregon does most of the government work around the area including TRI-MET busses.
If you aren't afraid of paying the money... Use this P/N,5015114AA, and search moparonlineparts.com.  only $161.
I just ordered a pair of AC Delco Pro (same as Raybestos Pro) ball joints so I'll let yall' know what I think when I get them. I also ordered everything to convert over to the 98-99 HD steering using AC Delco Pro as well.
Thanks for the measurement.
I tried to take my truck into a front end shop for them to give me a dirty alignment, but they poked until they found something off and refused to align it.   Yes I know the ball joint has 2* of movement, but that is not what is causing my tire wear......they tried to tell me that caster adjustment wasn't possible, then I pointed them to my adjustable control arms and they just said "well that won't wear tires"  Then I pointed out the wear was on the outside of the tire, and that ball joint caused tire wear results in the inner of the tire being worn.
anyways enough of a rant, I just hate hate hate dealing with alignment shops, I don't think any alignment shop has ever actually done and alignment.
Is this in C Springs?
No I noticed the issues about 1000 miles from home, Fargo ND.  I went in explained my issue and they gave me that run around.
I've NEVER taken a single vehicle I've owned to an alignment shop because of the BS you just went through. I've always done my own alignments at home and I've never had an issue with abnormal tire wear.
  • Jack the vehicle up making certain that it's level.
  • Find the middle of the tire and make a mark.
  • Using a piece of chalk or greese stick hold it to the mark you just made while slowly spinning the tire until you have a line around the entire circumference.
  • Roughly find the center of the tire and make a small horizontal mark across the middle mark on both the front and back of the tire.
  • Repeat the process on the other tire with one exception, your going to copy the center measurements of the first tire and use it on the second.
  • You want both tires to have equal center marks, it doesn't matter if they aren't exactly the center of the tires just so long as they are both the same. Say for example you measured 15" as the center of one of the tires. Your going to use that 15" measurement on BOTH tires so that they are both marked in the same place.
  • Measure the distance between the tires on the front side using the middle mark. Make sure the tape is level by using the horizontal center marks. Repeat on the back side.
  • Compare both measurements.
  • Example 1: Say the front measurement was 70" and the back measurement was 69.50". This indicates that the tires are toed outward. To correct your going to shorten the tie rod adjustment 1/4" and measure again. You should now have 69.75" on both the front and back of the tires.
  • Example 2: If the front measurement was 69.50" and the rear measurement was 70" this would indicate the tires are toed in. To correct your going to lengthen the tie rod adjustment 1/4" and measure again. You should now have 69.75" on both the front and back of the tires.
  • Remember that whatever the difference is between measurements your going to half it, then either lengthen or shorten the tie tod that amount.
Hammer, while this is a fine way of doing it i do believe my way is easier and faster. and still achieve the same results.
1 hour ago, joecool911 said:
You should do a video and put in articles section.
I've never made a how-to video before, sounds like it could be fun.
It's sounds like a lot of work but it actually only takes about 10 minutes to get your measurements. I thought you posted a video showing how you do an alignment but I can't remember where I saw it. Would you mind posting a link?
Edited by The_Hammer
Fat fingers + autocorrect = SNAFU
Alright,
Well the passenger front was about 1' closer to the rear wheel than the drivers....just like I told the alignment shop.   It was toe'd out about 5/8".   I took it in to about 1/8" +- to neutral.
Thing i s driving a lot better now.  I can only assume it won't eat through the tires as bad now.  Still curious why the outside of the the tire was wearing vs in the inside, but oh well.
Thanks buzzer for your measurement, help at least me figure out a good place to start.
