Having Line X Applied to Hood
- Replies 39
- Views 7.8k
JAG1 15 posts
dripley 6 posts
Mopar1973Man 5 posts
joecool911 3 posts
That's me That's meMy truck, camper and shopMy first gen flatbedWhere I want to be at all times I messed up cause it kept loading forever. Hey at least I got a beginning. Thanks you cu
Here is how to attach an Image
Two man process. First take a scratch awl and trace the hood hinges in their current position. The two men loosen both fasteners till nearly out while supporting the hood. Then both men at the
My fiberglass camper dripped Gelcoat residue all over the hood of my Black 2nd Gen nd won't come out of the paint. So Off I go to get Line X premium applied. Line X dealer wants me to remove the hood but I'm concerned how to remove the hood and not cause a crease when removing. Do you guys remove the front two bolts off first with a temporary board supporting the hood? I can see it maybe lowering just a bit while unbolting and causing a wrinkle.
Do you loosen all 4 bolts first while supported and then proceed? Thanks a bunch for any thoughts.
