2001 Manual transmission wont go into gear
- Replies 7
- Views 5.7k
rockcrawler69 1 post
dripley 1 post
TFaoro 1 post
Me78569 1 post
Hello,
I've searched and can't find anything so I'm looking for some help. My 2001 5 speed will no longer shift into gear. The last few days while driving down the road, when in fourth or fifth gear, speeding up to lane change or for whatever reason the RPMs would jump 500 and then back to normal. Didn't seem like clutch was slipping or anything. Long story short it started doing it consistently more the other day on the way home, and now it won't shift into gear with the truck running. I can turn the truck off and it will shift into gear fine. The minute I fire it up it won't go into gear at all. I checked the fluid and its full. Truck has 260K on it. I have never touched the clutch/tranny and not sure if the PO did. All I've found researching is that possibly the pilot bearing went out? Any other tests?
And to muddy the waters a little more... I have the edge juice with attitude. On the way home I would put it in stock , tow and mileage mode and the revving wouldn't happen, put the edge in 3, race or hot extreme mode and the revving would happen every time.
Thanks!
Edited by rockcrawler69
