- Replies 25
- Views 7.1k
Popular Days
Leave it untapped for a month at least. Drive it hard for the first pump. If any rebuild related issues are going to happen I would expect
The way I see it, you have to answer several questions. Do I need the extra power the tap gives me or can I drive/tow all right with the lower power setting? Do I want to spend the mone
Not really. I did a bunch of testing, rebuilt the motor, changed the tappet cover gasket etc. I waited a bit to tap the wire. I'd say at least a couple months to make sure everything is going to
I guess I'll be changing a IP next week so I have been reading over manuals to see what I'll need. I don't have a gear puller, I found this one on Geno's http://www.genosgarage.com/product/cgp010/tools. Is there any reason it wouldn't work? Something better?
Also, I figured that I'd put in a fuel pressure test adapter since I don't currently have that option. Maybe it will come in handy. Thoughts?
