- Replies 39
- Views 9.6k
Mopar1973Man 10 posts
JAG1 6 posts
AH64ID 5 posts
01cummins4ever 4 posts
Something is wrong. There should be no no health problems burning wood. You must have a cracked stove case or venting smoke into the house. I've have had stoves in the pass that cracked the case near
I couldn't live in a home without wood heat. It is unbelievable how many homes have the leakiest furnace ducts with insulation fiberglass dust being blown into every room everywhere. I've
I passed inspection, if you want to call it that, and am burning away! This is turning out to be a great little stove. +10°F outside when I lit the fire in the shop this morning. Shop is
How much have you burned this year???
Normally by this time of year, I'm well into the 3rd full cord of wood. Normally burn about 3 full cord per burning season. As of now; I'm probably at 1.75 full cords burned so far. Twas mild in October and November until the blizzard just before Thanksgiving..................then it got mild....................Most of January was cold......................Febuary and had mild and cold........................March has been fairly mild.
