High + Up & down RPM @ start up.
Hello every one yes It's me again!!
I have a weird Idling @ start up any time regardless of weather temperature and effecting battery amps. after getting warm abut 160 or 165 no up & down but still high rpm Please tell me what is going on?
Is there any way I can post the video more than 24.82mb so you can see Exactly what I mean? my video is larger than we allowed.
  • Replies 10
  • Views 3k
  • Upload to youtube then post the link here!
  • use youtube to host your videos.
  • If the lights are going bright and dim on cold start up, that is just the grid heaters cycling on and off heating the in take air. They draw a lot of power. i have to agree every thing looked pretty n
Thank I'll do it definitely.
In the attachment you can see the photos of it till I post the video.
OK friend at last I post my video on you tube and I don't how to share the link but I wrote it here it is:
I'll be honest, I didn't see anything wrong in that video. Pretty sure mine idles at the 850 mark in PARK and 800 in DRIVE. Ideally you want between 800-850 but it looks like your at 900 with one drop into the 850 range. I don't see anything wrong here though. :think:
Mines been doing that ever since I bought it almost new. I noticed some days it does it a touch more than other days.
Thank You. did you see the light going lite & bright ? when idles like that somethings uses battery voltage. as long as engine warmed up idles on 900 at park & 700 at drive. there is 2 video, 1 shoes idle & out side temp, other shoes idle & interiors light. look to (my ram 2500 weird idling part #2) video.
Edited by Sam53
If the lights are going bright and dim on cold start up, that is just the grid heaters cycling on and off heating the in take air. They draw a lot of power. i have to agree every thing looked pretty normal. Mine used to idle just above 850 until I put RV275 injectors in. The idle then dropped to 800 for some reason. Been like that for 6 years or so.
Thank You so much now it makes sense. I have to stop been worried and Appreciate every one how helped me for my idling problem so I'm going to closed this topic and start fixing the other parts for this old beauty.
