Destroyed Dana 70 rear end...
- Replies 53
- Views 11.3k
CSM 15 posts
Wild and Free 8 posts
Mopar1973Man 7 posts
notlimah 7 posts
I would guess it it was hanging on by a string and Mike just pushed it over the limit. Maybe we should all do burnouts before leaving to ensure that everything is good..
At least it happened where and how it did, was most likely already broke and this was the icing, could have snapped with a loaded trailer going down the open road then you would have had a lot worse t
I try not to be mean about it, but pics!
So, when back in my home town on some R&R/family time, I decided to do a simple quick, 5 sec burnout just for kicks and grins... right in front of my folks place just like old times. The turbo began to spool all normal, and BANG, followed by some minor crunchy sounds.
No pictures as of yet, but upon removing what used to be the cap on the axle, out fell several one inch triangles of axle, metal chips, and the bearing adjusting nut that formerly held the bearings. Near as I can tell, the axle broke and wedged itself in there and pushed the hub off about a half inch or so, breaking the nut as it came off.
The hub won't even come off as the bearings are wedged in there. They move slightly, but won't make it past the messed up tube and threads.
Edited by CSM
