W&F Hauling stuff part 2.
Tried to add this to my original thread but is locked as an archive now so on to part 2 as the title says lol.
Last weekend got the first gooseneck load behind the 2010 Hemi, had my B2150 Kubota tractor and box scraper loaded up inside the new to me 14' PJ dump trailer.
Just for reference I have air bags and a B&W turn over gooseneck hitch in the 2010 1500 Hemi. Hemi handled the load better than I thought it would considering I bucked 30+- mph winds during the trip both ways.
  • Replies 30
  • Views 8.3k
    Pretty soon it will be trailer time for me as well. This year I want to setup the 1996 Dodge Ram 1500 for my wood hauler. Being Dynamic did the 46RE transmission rebuild and upgrades. I can pour the w
  • Wild and Free
    Wild and Free
    Too manly? NEVER ha ha. This is about the most common size dump trailer around, only difference is mine happens to be a gooseneck which actually pulls a ton easier and better than all the bumper pulls
  • Buzzinhalfdozen
    Buzzinhalfdozen
    Don't mean to turn this into show and tell but I picked this up in W&F territory about a month ago.
Pretty manly trailer for a 1500!
:doh:Too manly? NEVER ha ha. This is about the most common size dump trailer around, only difference is mine happens to be a gooseneck which actually pulls a ton easier and better than all the bumper pulls behind all the 1/2 tons out there in my area, nice thing is the load is pretty much centered over the trailer axles rather than having a lot of tongue weight like some trailers.
Every thing I own has to earn its keep, have always been that way.:thumb1:
This load actually pulled a lot easier than towing my pontoon behind it which it sees almost every week during the summer time hopefully coming soon, talking 80's next weekend.:hyper:
Edited by Wild and Free
how to you get your tractor in an out of the trailer?
It has ramps just the same as a car trailer, these trailers are designed to be used as a skid loader or small tractor hauler. The ramps store underneath in the frame rails the same as they do on many car trailers. Buddy wants to try and use it to haul a small compact car but one would need to crawl out the window to get out lol.
Looks like the load sits the truck well. No squatting rear end. Stock suspension or have you beefed it up at all?
Pretty soon it will be trailer time for me as well. This year I want to setup the 1996 Dodge Ram 1500 for my wood hauler. Being Dynamic did the 46RE transmission rebuild and upgrades. I can pour the weight to the trailer now.
Wow, that seems like a pretty nice set up.  Are there tie down points in the trailer?
Yes, D-rings built right into the side wlls inside the trailer in all 4corners.
I installed air bags shortly after buying the 1500. It squats pretty easy with coil springs in the rear even with a fairly light load. I also have 3/4" leveling spacers under the rear coils and adjustable height Bilstein front struts set one notch below the highest setting, tried high setting and it caused a vibration at certain speeds due to the excessive angle on the cv joints on the outer axles the same as the 1.5 inch leveling spacer I had in it originally. Set it down one notch and it performs flawlessly.
Don't mean to turn this into show and tell but I picked this up in W&F territory about a month ago. image.jpeg
Edited by Buzzinhalfdozen
Where did you find it at and what are the plans for it?
I know it wasn't close to me, we have not had that much snow all winter in total.
I found it just looking through Bisman. It was about an hour SW of Jamestown.
My original plan was to cut it up and make a man sized hot rod/ratrod. Maybe use the bed for a redneck dump trailer idea I've been pondering. However it's way cleaner than I was expecting and I don't know if I can bring myself to chop it up. I don't have much grain to haul around here though.
You must have almost been in South Dakota then if it was an hour SW of Jamestown which is 125 miles straight east of me.
I believe it was around Streeter ND so more west than south I guess.
My lucky day it was snowing and windy there but nothing by the time I was back to i94.
I'm "trailered up" and hauling a load bright and early to welding shop.
Some managed to yank the track bar right off the axle...
Carefull with that load Mike, you have a lot of weight behind the trailer axles, she could get squirlly on you, keep the speeds slow and make sure the trailer brakes work well.
Are you saying you don't have a welder or just don't have time
I've got a bird crap welder. I need something I'm not going to fight welding that back up ad grinding for hours to straighten back out. So I'll get a professional local welder to do it.
  • 5 weeks later...
Just closed a deal on another trailer today, going to get it on Sunday. Sold my 30 foot triaxle flatbed which I just did not have use for a trailer that big anymore.
Found a 2009 H & W 24 foot " 20 foot deck with a longer gentle sloping 4 foot dove tail "  low profile gooseneck car trailer with 7K axles and a small 4500 lb 12V electric winch on it.
Has been stored inside its entire life and looks like new yet.
http://www.bismanonline.com/2009_h_w_24_tandem_gooseneck_trailer/?app_track=watchListMemberCenter
