- Replies 10
- Views 2.9k
dripley 2 posts
Dieselfuture 2 posts
notlimah 2 posts
leathermaneod 2 posts
So in the recent past, I had coolant spurt out of my radiator cap or overflow bottle. I know this because there were little spots all over the engine bay that were obviously coolant. I can't remember if my radiator cap had come loose allowing it to spray, or if it just came from the overflow bottle. I know at one point my overflow bottle was really high, like above the MAX line so I drained a little bit and then it seemed to be too low. I must've done this when the engine was still hot and just didn't think about it, so it probably would've just drained back down to a normal level had I left it.
Well I figured now is as good as time as any to change the thermostat and the radiator cap just so I know when the last time they've been replaced was. I got a new 190* thermostat from napa and a new 16psi radiator cap. Is 16psi right? That's what the guy told me there, but the one on the truck now is 15psi, so which is it? Or does it matter?
I'm going to take it to the dealer to have them do the flush, should I have them put any specific coolant in it? It currently has orange looking coolant, and I used some universal coolant so I could just top off the coolant until it's flushed, but is there specific coolant that these engines need?
