Travel trailer newbie!
Hey guys. My wife and I have found a great local company that rents 2015 travel trailers so instead of buying we will most likely rent for our travel/camping adventures.
Although I've towed plenty before, I've never towed a travel trailer and with that, not entirely sure of neccesary things I should bring.
For you more salty travel trailer guys, what are things you can't leave without when towing? Any sort of check list or things you've found helpful in the beginning of your towing days to stay organized and bring what was needed?
I try to be as prepared as possible, especially with the family involved, so I look forward to all of your insight!
  • Replies 126
  • Views 26.1k
  • Well had a good trip this last week. Went to to Lynden, WA for the Puget Sound Antique Tractor Show.    Mitch was the first real test in towing I've put the truck through and she did great.
  • Thats them. I know when I hook up and load with the 5th wheel mine sits level and I was surprised that the travel trailer you hauled made you look a little squatted. The leveling spacers upfront expla
  • I also have the camper package like @dripley without a leveling kit and it sits level when loaded.
55 minutes ago, AH64ID said:
Just increasing tires doesn't mean you can carry more.
Agreed!
It really depends. In most cases it's the operational limit of some component. The frame, axles, tires, brakes, etc
Typically in trailers, it's either axles or frame limitations.
Like for example, my BigTex 70TV is rated for 7,000 pounds with twin 3,500 pound axles. Now the BigTex 60CH flat bed trailer is 6,000 GVW. As you'll see the same axles are used in the two trailers so why only GVWR 6,000 pound limit? Because the frames are not the same. I actually stopped at the BigTex factory to ask about that and it not always an axle or tire limitation but a frame limitation could occur!
of all the trailer tires i've used over the years the carlisle and the hurcules were the best.
with the hurcules having a stiffer/thicker sidewall and lasting longer for me.
One of my flatbeds has the carlisle and the other had hurcs. and my 5'er has hurcs.
http://www.herculestire.com/tire-gallery/commercial/specialty/
oh and the hurcules are a fair bit let cash as well. all 4 for 380$ OTD!!!!
i'm at 5 years on them. still look great.!
 all though i see they've gone up some.
http://flagstaff.craigslist.org/grq/5623848284.html
Edited by Killer223
Generally yes.
My TT is a little different thou. I have a frame that is typically used on 10K-12K trailers and a pair of 5,200lb axles with a 7,900 GVWR. GVWR was determined by "delivery" weight plus 1,700lbs (IIRC) of payload. Not based on frame/axles/brakes/etc.
I'll admit I ignore my GVWR on this trailer. My previous trailer GVWR was matched with axle/frame and I didn't ignore it.
So for the sake of safety I suggest people stick with the GVWR rating of the trailer. There is rare times like AH64ID points out you can exceed some GVWR values. Since most people do not know the manufacture specs of there trailer frame, axle, tires, brakes, etc. I would still highly suggest to stay below GVWR. Less likely to have issues, failures or an accident.
I agree 100%. If you aren't sure then use the OEM numbers as you cannot go wrong.
We may not all follow the same do's and dont's but I think for the most part the members of this forum are very commonsensical people.....  I enjoy the round-tabling discussions too.
On another note, I was cruising down the freeway the other day doing around 73 mph in the right lane.  It was late afternoon and about 95* outside.  Traffic was light but there was still plenty of vehicles out on the road.
I was then passed up by a Ford F150 towing a TT.  I'm going to guess the TT was about 24' and they were doing at least 80 mph.  Not a terribly big trailer because I noticed the lighter weight tires and rims but big enough that this truck was sagging a little from the weight and the trailer would wag often, especially when he passed a semi.  The truck was probably around 10 years old but I couldn't tell as he was going too fast, although I did notice his larger aftermarket rims (probably 18's or 20's) with wide low profile tires.  He was on the throttle hard too as his exhaust was blaring when he passed by.
All I could think was I hope nothing happens to them because they had Washington plates and had a long way to go with some long freeway grades in front of them.
Katoom..... this argument you started over tires...... when your at the 2017 eclipse, I'm lettin' Michael use my 12 gallon squirt gun.
:thumb1:
:thumb1:
Heck with that I'm bringing a fire dept float pump and about 300 feet of 1 1/2" fire hose. I'll cool you all down... Then break out the beer... :cheers:
This just keeps getting better every post. If I fly in that means I will be unarmed. :badidea:
:thumb1: Your safe as long as you don't argue tire pressure/ weight ratios:thumb1:
I'll just show up late after everyone's to lit to remember any of this.....
I might have to stay sober just to meet you. We can discuss air pressure in our shoes. key word there is MIGHT. It is good to see you back around here.
  • 3 weeks later...
Mitch was the first real test in towing I've put the truck through and she did great. No complaints!
Had a nice little campsite setup
and of course, antique tractors!
Had a really great time!
Definitely had a fun time pulling with the truck but it's shed light on somethings I want to get done before towing again.
Mainly suspension type stuff.
I have a clunk in my front end somewhere that I THINK is my control arm bushings, so getting those swapped out. Also want to look at getting leveling coils and bilsteins valved for the trucks front and rear and lastly a shackle flip, but I'm not 100% sure how that really affects towing capacity.
Either way, the truck did fine as is, but it could be better I think. The truck sat pretty level, but that was with a weight distribution hitch. Had I towed without it, there would've been some serious rake.
Does your truck have the overload springs in the rear? Mine sits level 6k on the rear axle but I do have the springs.
