Flushing the coolant system and removing rust.
- Replies 12
- Views 9.4k
The_Hammer 3 posts
dripley 2 posts
DocH 2 posts
Buzzinhalfdozen 1 post
It's been almost 5 months since flushing the radiator with Evapo-Rust and the coolant is still bright green. I am still VERY impressed with how well it removed the rust from my cooling system ?
The radiator is easy to remove. I removed mine on the side of the interstate when the oe blew up. This was due to owner abuse more than anything. On the bright side I did get to inspect the interior o
I was having temp issues similar to yours, and then my radiator sprung a leak. I had to replace it, I went with the spectrum, a little tweaking to get everything lined up on the radiator support but n
The previous owner of my truck ran straight tap water for who knows how long before I bought it which caused the cooling system to be contaminated with rust. I've been dealing with the issue off and on since buying the truck in 2011 and finally got around to taking care of it
I was doing some research on eliminating rust from the cooling system when I came across a product called Thermocure by Evapo-Rust. It has some really good reviews on Summit Racing and looked promising so I ordered up a quart $26 shipped.
I removed the thermostat and flushed the cooling system everyday for a couple days using tap water until the Thermocure arrived. I drained the water, added the Thermocure, then refilled the system. I drove the truck for three days before draining and flushing the system a few times with tap water. Below are the results.
From left to right: Initial draining after three days, second flush, third flush, and fourth flush. After the fourth time I stuck a water hose in the radiator, opened the drain, started the motor, and let it run for about 20 minutes until there wasn't so much as a trace of rust showing in the bottom of a clear one gallon jug.
I'm about to flush the system one last time with distilled water to remove as much of the tap water as I can, install a new thermostat, then fill with 3 gallons of concentrate and 1 gallon distilled water for a 50/50 mix.
