Log splitter
Hand splitting gets old. Don't have much in the budget for a new hydraulic splitter. So I've been eyeing a small kinetic splitter. Ima bit loyal to DR so i was thinking about getting their model. For a small kinetic and electric splitter it looks impressive.
What's everyone think about the kinetic splitters?
I'm only splitting for myself also and its mainly birch sometimes some pine.
Edited by hex0rz
  • Replies 24
  • Views 6.7k
  • Upgraded the 'ol log splitter today (11/17) with one from Tractor Supply. The old one was a little light duty personal use machine, I borrowed from my son. I installed a new pump, control valve, filte
  • Yes, there are pros and cons to all of them, look at all the little things when you research. I think PJ has a really good spec table to compare trailers. I prefer the scissors lift, at least 10 gauge
  • The list of people allowed to borrow my stuff is very short.....and if you aint blood related then you're not on it.  Got tired of fixing something someone borrowed and returned damaged.
It's got bad reviews for little power. Not able to split thru green logs or hardwoods. Not enough power and having one flywheel instead of two like most kinetic splitters makes it limited. Owner that bought one said go hydraulic. Only one person reported great machine and gave it higher marks but the majority said not so good.
I have been hiring some young guys to split mine but it's hard to find guys that split wood like I used to when younger. I had overwhelming ambition.
I burn wood all winter.  Bought a splitter around 10 years ago from Tractor Supply.  The biggest one they had.  I think its 28 ton and it will shove though most anything I can get under the wedge.  Wouldn't want anything smaller either as I've had to split some really ugly wood that doesn't "split" but rather tears apart or simply explodes in two halves.
I used to have a hydraulic. But I'm not really worried about what comes with one.
Where are you seeing these reviews on the dr splitter? Dr has like 4 star reviews on it.
I should have put up a link for it. I just googled reviews on the DR kinetic log splitter and went down the list. 3said not so good and one said great unit.
Having a log splitter is like having a car trailer, once folks find out you have one they all come to borrow. Mine is usually only at my house about half the year. Neighbors who heat their shops use it more than me for my 3-4 cord a year needs mostly for my mother in law. Mine is a 20 something ton Husky from TSC too it was a model that was weathered and faded pretty bad that sat outside the store for a couple years, I talked the manager into selling it for cheap as it looked like hell for a new unit, he called his district manager and I got it for almost half of what it was listed at.
Edited by Wild and Free
I'm lucky one then... Rarely ever barrowed. I managed to sell my service of splitting firewood.
http://www.arboristsite.com/community/
A web site I visit on occasions, a lot of good infro on their. I know that the kinetic splitters have been improving a lot and going with a company like DR. you might get a quality one, but the electric or hydraulic ones in the 6-10 ton range are no more than bench top or inside shop splitting, and don't think they would keep up with the heavier stuff if your relying on heating your entire house with wood.
I personally use a 3 point log splitter mounted to a 25 horse kubota, I built my self and got less than 500 in it. It serves me well with about 6 -10 cords a year, but probably wouldn't keep up with the high production splitting.
This is the splitter i was talking about. The k10:
I'm not sure I like the part where you have to lift logs on to the splitter.  My splitter has a ram which pivots and stands on end.  I simply roll the rounds over to it and set them under the wedge.  I'm generally muscling large rounds too so having to lift them up on the ram would be kind of a pain.
The ram is fast, the downfall I see is its so close to the ground your going to be bent over a lot unless you mount splitter on a bench or something
the wood they use on the demonstrations is always knot free and probably well seasoned, so easy splitting, What about continuous duty and knotty wood, If the logs get hung up in the wedge you would probably have to beat it out with a sledge, just extra work.but other than that it would probably work fine for the light duty stuff
  • 2 years later...
Upgraded the 'ol log splitter today (11/17) with one from Tractor Supply. The old one was a little light duty personal use machine, I borrowed from my son. I installed a new pump, control valve, filter kit and flushed/cleaned out the tank. Then ran it a few days and changed out the hydraulic oil/filter again, then took it back while it was all freshend up. Figured I should buy my own before I wore out his again, plus I was getting afraid of the Chinese motor, lol.
Mine is a 25 ton with a 11 second cycle time. It will work me hard to keep up. I don't burn wood but I sell it. Lots of work but it keeps me healthy.
I hope the one with the open toe sandals is just a looker and not a helper. I like your trailer. :thumb1:
The flip flop person has to learn the hard way, Lol  It is a good heavy duty trailer but I would not buy a low pro again. It is nice for loading equipment but the bed gets to close to the ground when you dump. It is a 7'x16'x3' Lamar with 7 gauge floor and 8k axles.
I'm in the market for a dump trailer...  Any suggestions?  What to look for and what out look out for?
Edited by KATOOM
I have a Pequea C2500 6.5'x12'. It's perfect for me and my fire wood operation. My '58 Ferguson or 1835B skiddy fit in nicely. It's 9999 GVWR which is also good for me because in PA anything over 10k is considered CDL and subject to a whole other array of California like regulations.
100_3441.JPG.3e5135f90e62bc17cb24c2feaa98faf8.JPG100_3442.JPG.2e032ca7eabcab7cc2e53221d3d521e2.JPG
I'm currently looking at a Patriot 7x14 dual ram 14k or a Big Tex 7x14 scissor lift ram 14k.  They have their differences but its amazing how many differences are out there in the dump trailer world...  Trying to figure all that out before I make a purchase too.
Yes, there are pros and cons to all of them, look at all the little things when you research. I think PJ has a really good spec table to compare trailers. I prefer the scissors lift, at least 10 gauge floor and sides, 3 way gate, ramps and tarp kit. I also want the fenders to be attached to the bed. The gap between the frame mount fenders and the bed is a catch all. Pay attention to the side wall supports, some are light weight, also the top rail/stake pockets. Here is a picture of my Big Tex (sold), Lamar and Load Trail.
