Drum brake adjustment
- Replies 25
- Views 73.7k
angus 7 posts
KATOOM 6 posts
01cummins4ever 3 posts
worldclass1 2 posts
I've always made sure everything is clean and freely moving and properly fitting. Then adjust out the star so that the drum barely slips over the shoes. Then adjust the star out some more so that wh
Today I adjusted the shoes all the way out, then backed them down about half a turn. went for a test drive and no real difference... I think I was already pretty close. I decided to try @Mopar197
So I finally got some time and crawled under the Dodge and popped the lever off the load adjustment valve. I raised it all the way up and it actually fell back to the 11:00 position so I just tied it
I`m going to be doing some work on the old GMC 2500 today. It has drums on the rear and I would like to check the adjustment.... In the past I have always dialed them in to the point of installing the drum and not being able to feel any friction.. My understanding was that should self adjust any time you back up with the brake applied??
I`m just looking for input from anyone who might have a different theory..
