  • Popular Post
It finally happened... The Edge Comp has been removed from my truck and replaced with Quadzilla Adrenaline...
Ok let me back up and tell a bit of the story here. First off I've got to say thank you to several people. @Me78569 for coming for with a crazy idea that will benefit everyone. @Quadzilla Power for sending me the Quadzilla Adrenaline.
What is happening is @Quadzilla Power and @Me78569 figure I'm one of the few big MPG guys out there and would be awesome if the Quadzilla could possibly put me higher on my MPG high mark. So in end result, Quadzilla would have another platform of advertising at the angle of MPG's as well. As for Mopar1973Man.Com we would hold the article for how I got to my new high mark of MPG giving us the internet traffic. More or less a win, win for both sides.
So out of respect for @dieselautopower (Owner of Quadzilla) and @Quadzilla Power for the module you now see their banners on the site.
Now on to the learning curve of Quadzilla tuners and been bouncing back and forth between @Me78569 and @Quadzilla Power for tech support and understanding of different things. I'll also be helping out with drivers but seeing if the "Linux people" can safely update over VirtualBox.
As for first impression of the Quadzilla comparing to Edge Comp. Way more power. I've posted several of my OBDLink screen shots with roughly 400 HP and 1000 FT/LBS of torque. First run with Quadzilla wide open buried my Torque gauge at 1,200 FT/LBS and past that. HP was right around 440 HP. This is about right when you math out the mods (235+50+180=465 HP) as compared to Edge Comp (235+50+120=405). This is just right out of the box setup and running @Me78569 custom tune he built for me based on his current tune he's running. So after cleaning up the code as I learn I'll get more of the power out of it. Right now comparing the smoke between Quadzilla and Edge Comp there is way less with @Me78569 current tune. So that explains why the power is a bit short yet. So with the help of @Me78569 I'll get this tune cleaned up and working better.
So now on to the goal of attempting to beat the MPG high mark now.
As for photos I'm too shy to take a picture of my install as of yet bit roughly installed in a hurry and want to clean it up before showing off. Also have a wild idea on install change I want to attempt to do being I like to power wash my engine a lot and also want the module easy access for flashing new tunes. (More to come here).
  • Replies 158
  • Views 27.4k
    Recomplied...
  • Let's say a typical truck gets 17mpg. Let's say the quad bumps the mileage by 2mpg. Let's say fuel is nice and cheap, $2.15 Remember, the more expensive fuel is the faster it's going to pay for i
    Installed and presentable...     Both my Bluetooth devices operational...
So from what I can see you only have noticable smoke on lvl 6?  Would you agree?  Also seems like smoke is much reduced after things are warmed up, at least that is what I could see in the video when you where on 6 and stabing the throttle on the runs at the end?
Thanks for doing the lvl3 so we can see what the smoke is a result of.   Would you agree that there is no smoke on lvl3?  I want to make sure what I see in the video matches what others see.
I think if we were to up the low limit for the wiretap to 12psi, rather than 7,  it would get rid of all the smoke.
Where do you feel the quad and Edge are equal power wise at? Edge on 5 quad on what?
any other thoughts or impressions?
Level 6 seems to blow a cloud but nowhere near as dense as the Edge Comp.
33 minutes ago, Me78569 said:
Would you agree?
Yeah, just very mild short burst cloud.
Actually, I was at full coolant temperature before starting any recording of the video. As for the Edge and the First Quadzilla videos those are running up hill, where the 2 Quadzilla video is running down hill the percent of grade is very mild like 1% or so.
interesting
I would bump the wiretap low limit up by a few psi and see if smoke clears.  but for the meantime just enjoy the tuner and see if you can't hit 29 mpg.
Yes. Level 3 is completely clean.
Quad on level 4 vs. Edge Comp on 5x3. Even @Mopars Mistress agrees there is more power now than before...
Here soon I've got to drag a trailer. So we'll see how the tune does. If you want go ahead build the new tune I'll gladly flash it before pulling the trailer.
The only thing I did see that is surprising is the boost gauge (Quadzilla) vs boost gauge (ISSPro EV2) there is a 5 PSI gap. So Quadzilla shows 35 PSI then ISSPro is only showing 30 PSI. To confirm this I set the boost limit on the Quadzilla so I could pound the throttle and watch both hit a limit and hang and see the difference. I would have to say the engine sensor is inaccurate than the ISSPro EV2.
I don't think there is any difference.   the box is the same, just the coding on the box is updated with this.
@Mopar1973Man
Interesting on the boost gauge.   Not really a huge deal for me, but I would be curious to see what others noticed.  Mine reads pretty close to the gauges I have compared to in the past.
When you are changing the setting on your quad are you doing it via tablet or phone? Is their a base line in the setting you are using and then changing as you go?
Yes. There is no controls other wise.
@Me78569 Started me with a custom tune right out of the box. So I've never seen the factory Quadzilla tune as of yet.
Power wise quite surprising how much pull this beast has now compared to the dirty tune of Edge Comp. I'm now working to understand the optimal driving method to gain the most of everything. I can tell you there is an audible difference timing wise between the Quadzilla and Edge Comp. Edge Comp was very aggressive at cold startup in cold weather. Quadzilla so far is fairly mild in cold weather startup.
@Me78569 Has another custom flash for me to try out tweaking even more... Try to get that done today.
@Mopar1973Man
Ours reads differently on our test truck as well. Usually 3-5psi difference. I've noticed on the IssPro I'll hit 40psi at WOT and the Adrenaline will show 36-38psi. It could be that one is mechanical and the other is electrical. I guess some guys have a huge ordeal with how much boost their making, considering we get 5 calls a day asking why they aren't making 100,000,000psi like they were with the "other guys" module they had. 3-5psi isn't going to make that much of a difference, IMO.
I've alway knew about the inaccuracy between MAP sensor and boost gauge. Just know that I've seen it I can clue other that are solo to a module like Edge Juice or Quadzilla Adrenaline that the gauge is not accurate for true boost pressure numbers. Not saying that Edge or Quadzilla are to blame but the MAP sensor itself being it's getting all the data from the MAP sensor for boost fooling.
I'd imagine knowing this would be helpful when setting up the quad as well because you are setting fuel values at a particular boost level....
Most likely why @Me78569 has to bump my tune to 12 PSI on the wire tap because I watch the boost gauge not the phone display. I know I need 10 PSI for clean run but if the MAP sensor is off then that why I still hold that small puff smoke on my wire tap levels.
Exactly why I bumped up the low limit, you may be hitting that low limit before you should be and over fueling.
Who knows what causes the sensor to be off.  Might be an old sensor or maybe just the nature of the beast.
Again doesn't bother me because I don't pay much attention to psi.
I have a 3-5psi difference until I get into the mid 40's, then they remain dang near perfect until the MAP sensor is maxed out at 62psi.
Mine kept having a dirty "puff" like you have mike. @Me78569 and I determined it was because the boost was flying up and the refresh rate wasn't fast enough for a smooth curve in fueling. That's why my 15psi percent is lower than the surrounding percents. Lowering that effectively smoothed things out.
If yours is all wiretap, I'd just hold off on the wiretap until a higher boost to keep it clean.
That what this next flash is jumping back up to 12 PSI to clean up the wire tap transition.
