Tie Rod Ends Stuck! 1999 Dodge Ram HD Steering
- Replies 18
- Views 3.1k
JAG1 4 posts
IBMobile 3 posts
Royal Squire 3 posts
TFaoro 2 posts
Popular Days
Use two large hammers. Hold one solid against one side of the knuckle(the hole that tie rod goes into) and whack the other side with the 2nd hammer. You can alternate hitting around the circumference
Pickle forks are worthless and are good at only destroying things you may want to reuse. Best is a good heavy hammer and some good hard wraps against the housing itself not the actual tie rod. Th
I all ways start out doing it this way↑ and if that doesn't work this way will↓
Ok, so I've had a bad shake/wobble on the highway for a few weeks now. I had a third gen adjustable track bar with drop bracket, Carli Coils, Bilstein 5100s, TGC tubular upper and lower control arms and some nice tie rod ends and so I had my buddy install them.You really need a pretty nice spring compressor to install these springs right because they are so much longer than the oem springs. I had the rear u-join on the driveshaft replaced as well while it was sitting. It was the only bad one. So I've tried two different pickle forks, and a small press so far. I flipped the castle nut over and hit the top of the nut with a small sledge. They aren't even budging. The small one on the driver side, which is more like an edge isn't even very old and it's giving me problems too. So I'm curious if there is a trick to this. My truck has the HD steering which is the good stuff. Does anyone have any suggestions? I'm running an errand so I'll take some pictures and upload them when I get back in an hour or so.
Edited by Botlebruiser
