- Replies 11
- Views 3.1k
Me78569 3 posts
leathermaneod 2 posts
CTcummins24V 1 post
TFaoro 1 post
Hey guys,
So with moving lately I've had the chance to make more long trips with my truck, and also done a good bit of lower speed back road driving. Also done a good bit of trailer towing lately. Some empty car trailer, some loaded car trailer with a tractor like in my thread about first time towing, and some loaded 6x12 enclosed trailer. Nothing too heavy, I would say 8k max and around 3k average. Anyway I've been noticing my average MPG numbers with all this driving and they aren't where I'd like them to be. Unloaded on the highway doing 65 mph with 3:54 rear, best incan get with the edge is a little under 19. With the smarty I used to have I could almost hit 22! Now I never towed with the smarty so I don't have a comparison, but I would say mixed around town driving and towing I'm getting around 15-16. After my trip from PA to VA yesterday the scangauge is showing about 15 and that was with the 6x12 enclosed trailer loaded on the way, unloaded on the way back, which isn't all that bad, I'm just trying to figure out why my numbers with the smarty were better and why I can't do even close to as well as @Mopar1973Man? I still think my injectors aren't the best, but after seeing mikes videos, I don't think I'm smoking more than he was with his edge comp. why can't I hit low 20s unloaded on the highway? I have stock size tires. All maintenance is caught up on, no brakes dragging or anything, all fresh fluids. Should I switch injectors and see what that does? Maybe try more or less 2 stroke(I'm using about and oz per gallon right now)? Maybe try optilube instead? Quadzilla? What are your thoughts? What would explain the drop in mileage going from smarty to comp? Bye I always run with the MPG fooler turned on even in summer because my iat temps are only around 100° even when it's hot out. Could that be hurting me?
Edited by leathermaneod
