Fuel tank and In-tank pump vs engine mounted lift pump help
- Replies 37
- Views 8.2k
dripley 10 posts
DocH 9 posts
JAG1 4 posts
01cummins4ever 4 posts
Dripley, no wonder your the boss... you explain things real well.
That Airtex is what I have as a back up/priming pump. When I have used it fuel pressure is 15-17psi at idle and down to 10psi wot.
Any illuminating in those warning lights and you are in the red zone on fuel pressure, I have a BD warning light as a back up and it will come on very dim at about 10 psi, and fully illuminated at aro
Hi Guys!
1st want to say a BIG THANK-YOU to all RE the Timbo, new alternator etc!
Running well, but low fuel pressure at VP44.
So dropped the tank and found the bottom of the "module" screens were clogged.
Local Dealer has no parts other than New In-Tank pump system, and recommended gentle cleaning with a soft tooth brush and brake cleaner fluid.
While Gently cleaning the the bottom screens, the top one ripped.
My wrench guy removed the little spring unit that seemed to fit between the screens. (I think I said that right.)
We then put the new float level unit on and after cleaning the bottom screen, re-attached it.
But He did not put the spring thing (see pic below) back in the bottom piece of the white in-tank unit (Where all the tubes and wire connector for the level float are housed.
Will it work that way?
The lines look good..it looked the only problems were the fuel level sending unit was dead (gauge always read the tank had much more fuel than it did.
The tank is still dropped...but can We put it back in with out the spring-prong thing in the pic?
With the clogged screens, the New Airtex lift pump was providing just barely 5 psi to the VP44 at idle ( The low pressure wrning light stayed out), but with barley any throttle applied the warning light came on.
It had decent power, but I quit driving it until We could figure out why the lift pump was not providing enough pressure.
The Airtex E7153 specs show 15-30 PSI and 55gph free flow.
Now that the screen is clean, albeit missing what looked liked the upper screen, where it looked like the spring-prong unit fit, will it work?
The rest of the lines to and from the VP44 are new, and the return banjo bolt on the VP44 is replaced....
Suggestions, or just re-hang the tank and see what happens...
Thanks Guys
Ed
