- Replies 12
- Views 4.3k
JAG1 3 posts
IBMobile 2 posts
CTcummins24V 2 posts
moostang 1 post
Popular Days
I go to auto body paint supply stores. Some of them either have in stock or can get the 'exact' color in a spray can.
Disconnect the batteries' negative cables other wise you risk over voltage across the ECU and PCM.
Here's duplicolor rattle cans...in the sunlight you can definitely see the difference. White should be easy though
I'm going to do some rust repair on the bottom of my doors and I'm just going to use rattle cans to paint. Does anyone know of a good paint that will match fairly close? It doesn't have to match perfect, I'll just paint up to the trim.
