Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 308.8k
  • Quadzilla Power
    Quadzilla Power
Take note @Youngblood24v your running 7 x 0.010 injectors vs my 7 x 0.0085 injectors so you'll need to be below 15% to reach 21 MPG. Bigger the nozzles the lower in the engine load percentage you need to be. Just to show how this works...
Engine Load = Quadzilla CANBus Fuel / 4,095
So if you have CANBus Fuel of 2,000 on the Quadzilla that is equal 48.8% Engine Load. If you want MPG you need to address all rolling resistance loads, drag, excessive weight, etc. Either way you need Engine Load numbers down as low as possible to gain MPG's.
Im we’ll aware of the fact that I’ll most likely never see 21mph. If I were wanting higher mpgs I would be driving a car ? I’m very happy with my 16mpgs
I'm going to break my old high mark of 27.2 MPG with a 8,000-pound truck. Done it once I'll do it again. So don't give up. I'm going to at least reach for my old mid 20's like back in the days of Edge Comp and +50 HP Vulcan Performance Injectors. If I can reach the mid 20's then I know I can break my record. I've got work to do to my truck to do it. Right now there is minor issues like parking brake cable rusted up and possibly dragging brake shoes. Valve Lash. There is a few other things I'll look into.
14 minutes ago, KMayborn said:
I have all the aerodynamics of a brick. Ill see if i can attach a picture of my rig. I know its not helping but just trying to get the best out of what i got.
You got the aerodynamics of mine but I only weigh around 8k lbs thankfully. ?
I wish i could shed weight but it would make my job alot harder. Soon ill be buying a new machine thats 5in shorter and 200lbs lighter but 15k price tag is hard to swallow when i didnt even pay that much for the truck. haha
So for those of you asking for my setup:
02 Dodge 3500 Dually
H.O. 6spd 4x4
Valair 550hp clutch
Fass Titanium 150
3.54s With 235/85r16s.
Edited by KMayborn
Personally would compound with big injectors and tune nicely
 MlPersonally would compound with big injectors and tune nicely
@silverdodge Thats the plan but just have to do it in steps. Studs and injectors first, then rebuild the hx35 and buy a s472 and build the piping.
Play around with it and see if you can notice an drop in egts by increasing or decreasing.  My truck however liked that 20*-21* mark at 2k rpm
Will do. Just hard to watch it while driving in traffic.
I read some where that timing between the H.O. and S.O pumps are different, should i be taking that into account when playing with timing?
I think i have squeezed as much as i can out of it for being as heavy as i am, do you think as set of 4.10 gears and 33in tires would be too much gear? It should put my cruise rpm at 2133 give or take.
I wouldn't worry about ho vs so.  Just make small changes and see if things change over time.
So i was talking with Dap and they suggested a 225hp (7x.012)  injector if I go compounds. Is it feasible to turn them down enough with the v2 to run them temporarily on a hx35?
If not i think I’m going to stay with a single for awhile and run a 62/68/12 sxe.
Edited by KMayborn
Some guys have, it is not a long term solution though.
It would only be for a few months till i could afford the second turbo. I really don’t want to have to buy injectors twice but if it’s not advised at all I’ll just  stick with the single.
Saw a video of a guy tuning a he351 with 7x .12s. That’s not much bigger than a hx35 is it?
Define long term lol
Probably was @Me78569! Lol
I’ll be in the same boat as you shortly running big injectors on an HX. Definitely not a permanent solution but I can imagine anything being wrong with running for 6-12 months as long as you were nice.
That was me.  The he351ve does about 9lb/min more than a hx35.
As long as you drive semi smart you will be fine.
What are your hours goals?
Id like to be able to be around 500 to 550. No more than what my clutch will handle at the moment. Daily driving would obviously be lower.
Looking at either doing a 62/68/12 with 7x.010s or if i went compounds a hx35/s472. If i go with the 62/68/12 now i would run it over the s472 later down the road.
I’d go 7x.012 now. You can tune them back with the quad and once you get a 62/68/12 or compounds you’d be fine.
Thats what i want to do but i have to keep in mind that my truck weighs 11250lbs on a daily basis. Commons sense says to stick with the 150s for now but the lust for more power says go big or go home. lol
