Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 362.1k
  • Quadzilla Power
    Quadzilla Power
I wont say anything until I see datalogs.   Without those it is a complete shot in the dark.
What is your 1500 and 2000 set for? If your 2000 is set for 18 degrees then a plus 1 would be 19 or plus 2 would be 20. That is how you figure cruise timing.
It's actually +2 or +3, because if I'm not mistaken, there's still a degree added when you're over 55 mph.  Or did that go away @Me78569
Got a decent data long this morning. I am sure u dont the whole data log. How is the best way to upload what y'all need to see?
put it in a post. and tell us what lines are what situtations.
You might
Timing Reduct Scaling: 50 or 60%
Low PSI Timing Reduct: 5*
that will drop timing a little more when you go to pass.
however otherwise I dont really see anything to worry about in the logs.
10-4 I'll give it try. Timing reduct scaling was at 100 so I'll got to 60 to start with.
You need to increase timing reduct as well to get the desired effect.  You will get less timing pull if you don't.
Hey everyone,
I was wondering if anyone has a completely stock truck with the quadzilla adrenaline v2? I've been tinkering with it for a while now and think I've got it pretty close, I was just wanting to compare it to others and try theirs to see if maybe I should add something or remove something somewhere. BTW y'all have some badass trucks haha I'm still working on mine, hopefully one day soon tho :thumb1:
@BrokeAssPainter are all your mods in your sig?
What gear ratio, it it Auto, stock injectors, how many miles truck/injectors, hx35 or hy35, timing is low, do you have head studs. What are you seeing for maximum boost, light throttle too high (40) should be closer to 20ish. But then again with your big tiers...  your canbus is basically maxed out at 10psi, you need bigger injectors and maybe few other things. :2cents:
I may not respond right a way, but it'll get the ball rolling.
That looks like a pretty typical stock injector and stock head stud tune.
You can run more timing up top and gain some power.
Try
2500: 23*
3000: 28*
Max: 30*
Ok sweet! I've just been kind of nervous messing with the timing, I keep reading about popping the head gasket from timing and I definitely don't have the time or money to fix THAT issue right now especially since I just noticed my poor little Hy was puking a little oil out of the front yesterday :duh:
Oh yeah one other thing, so when my t.c. locks up in 4th it's usually around 1400-1500, and the truck completely looses all balls, it still has power it's  not dead pedaling on me, it just seems like it has no guts under like 1700 rpm in lock up.... I really appreciate the help, y'all help me keep my sanity :thumb1: I'm the only one of my friends who actually knows anything about mechanic work so it's difficult sometimes lol
more timing up top is perfectly safe, you just dont want a ton of timing down.
Ever edge comp out there is maxing timing at 32* be ~3000 rpm at heavy throttle.
Try increasing load offset timing to help with the locked 4th shift.
Dieselfuture I just now saw your post, sorry, yes it's a hy35 47re 242,000 miles and 3.55's I think :think:..... It's an 02 2wd qc long bed so not real sure the gears, but when I say stock I mean stock, hell I think the silencer ring is even still in it lol original injectors and all
