Fuel sending unit question
- Replies 11
- Views 3.1k
JAG1 3 posts
dripley 2 posts
015point9 2 posts
Dieselfuture 1 post
Popular Days
Mine has never been that accurate. it takes 120 miles before the needle moves, 300 miles to the first 3/4 mark. Second half of goes pretty quick. But it is consistent every tank. I have grown used to
show off.
It takes even more head scratching if you have a short bed!!
My fuel tank is out right now and my fuel gauge is not very accurate. Thinking now would be the time to change fuel sender, being tank is already dropped.
Question...to test the new sender before installing tank back up...
can I extend the wires using jumpers maybe 4 feet to test new sender that would be laying on ground about 3 feet away, fill up maybe ¼ and turn on key , repeat at ½ to make sure new sender is working OK before I put tank back up?
Is that a "go" or some reason I shouldn't?
Thanks
