Passed on the power wagon... picked up this!
  • Popular Post
As awesome as the PW is, I found something i like better for less!
My grail c body cars are 60-61 chrysler and 66 chrysler 300.
Very clean car,  1 owner, 383RB 2bbl, push button auto.  The only rust is in the trunk floor, even the fenders and trunk extensions are clean.  Best yet, it runs!  It needs a thorough once over before being driven, but everything works!  Not bad for 2500 bucks!  I hope to put a megasquirt tbi efi system on it, recover the seats, new exhaust and drive it!
  • Replies 37
  • Views 10.9k
  • Update:     Runs & Drives...  Ok, it occasionally coughs, but hey, it was in a coma for 8 years.  It just needs an enema!     After Nick and I dove in early on, I kinda got in
  • I added a MSD ignition system. The old distributor was shot with no vacuum advance and the timing parts drifting all over the place.  The parts to rebuild it aren't in production and NOS parts are ext
  • Thanks to Nick, we got it running today.   New fuel pump and running out of a gas can, but it started right up.  It needs a new starter and the engine is FULL of some really nasty sludge.  Howeve
31 minutes ago, Me78569 said:
I can't wait to take a spin in that bad boy
Golden Super Cruise next summer...
There's one here in my neck of the woods too. It is for sale but looks like a borderline parts car.
I like yours a lot and I'm sure it comes with some iron.
Looks like the Batmobile.  I had a 68 dodge 4 door Monaco with the 383 2 bbl. Car had some iron in it for sure but that engine let haul the mail. Loved that car and it only cost me about $400 bucks back in 74 or so. Sold it about 2 years later for $200. Are you going to pull your Barricuda with it?
The Golden super cruise is a blast! There is a white 300 that was at the last cruise in September with a cross ram 413. I'm a sucker for the big block land yachts!
Haha.  No.  I dont know what the long term plan is.
We should meet up for it at some point.
@Mopar1973Man  I may need help wiring up a high idle switch for it!
We should definately meet up at the cruise sometime! Maybe get@TFaoro and @Me78569 to come along.
Very cool.  Those tail lights look like something out of Mad Max.  Looks like Chrysler has had dash issues for a while! :lol3:
4BT swap with some beefed up suspension :stirthepot:
:think:Hmmmmm!!!
I like tractor sounds.  I like car sounds.
4bt is not in the cars future!
New fuel pump and running out of a gas can, but it started right up.  It needs a new starter and the engine is FULL of some really nasty sludge.  However, the trans works, it charges, and it should be on the road soon.
A couple taps on the carb was all it took to free the stuck float, and even the accelerator pump works.
Im planning on flushing the engine with some snake oil and multiple oil changes.  After that, mabe pickling the cylinders to try to get the rings clean.
Edited by CSM
It was a good time today man.  Let me know when you want to give her an enema.
Awesome.
I need to pull the starter.  Theres a shop in the springs for alternators and starters if i cant free it up.
Then the plan is to going to auto hobby shop to pull the pan, then the enema will commence... along with the fuel lines, filter, etc.  Ill let you know.
  • Popular Post
Update:
After Nick and I dove in early on, I kinda got in stuck in the trenches of newborn dad life.  Currently the kid and I are kind of like North and South Korea.  Some days, theres lots of sabre rattling and posturing but other days it is great.  I took advantage of today and was able to get the other big stuff finished that Nick and I did not get done last time.
What works
The factory fuel system now works!  The car has oil pressure!  The original oil pressure sending unit gave up the ghost I think, as a manual gauge popped right to 40 pounds and stays steady.  The car even has plates.  The lifters still have an occasional rattle to let me know they are there, but I am hoping they are just gunked up and will loosen up with some quality oil and driving.
The old generator system works flawlessly. Though by design it doesn't charge much at idle, it jumps right as soon as the RPM goes above 850 or so.  The turn signals work, the brakes mostly work, the E brake works but doesn't disengage without an special verbal incantation I have developed with one hand under the dash fiddling with the mechanism.
What don't work
I need to reattach the brake light wiring to the master cylinder, as they were smoking from missing insulation.  The speedometer cable is supposedly disconnected, no idea why.  Passenger side rear window won't go down, hopefully an easy enough fix.  Numerous little nuisance electrical items like the temp gauge, the dash switches need their 57 year old contacts cleaned, and the long out of production non gear reduction Bendix starter needs rebuilt.  Chrysler has used the same starters since 1964, but that doesn't help me!  The trunk floor has holes and the exhaust needs replaced. The only real show stoppers that I need to fix asap are the starter and I need to fix some holes in the copper radiator.  Aside from all that its good to go!
Hopefully I will be driving it to work daily very soon after a couple shakedown drives.
https://youtu.be/OnJBEAYoH60
Give me more detail and or pics of the power wagon you passed up on, that would interest me a great deal.
Texts ok?  I still want the power wagon! Haha.  But i doubt that will happen.
It is mint.  The only downside about it is closed knuckles.
Friend of Mine bought an early 70's 2500 4x4 four door crew cab from California with a 440 and auto that is super mint as well but he paid considerably more for his.
Crew cab dodges are really expensive right now.
She was more than a little fussy getting off the trailer.  A full tune up is in order.  The funny thing is that once in the garage, the car ran fine.
Edited by CSM
