- Replies 56
- Views 14.7k
notlimah 17 posts
dripley 12 posts
JAG1 11 posts
Dieselfuture 4 posts
Guys, There is no pressure if there is no resistance to flow.... Think on that for a second. If you took all your injector lines loose and ran the vp, how would the diesel look comin
Notlimah, I'm not joking. That's the stock engine fuel return that was going to the fuel tank. I plumbed it there to keep hot fuel from being picked up inside the fuel canister.
All I know is everything Dodge did to the fuel system was so bad in my opinion that it became my mission to change everything about it. I.E. W/S fuel filter before the lift pump Cut out
Hey guys, looking to get a new, or at least longer, fuel return line for my fuel module. I installed Vulcan's drawstraw 5 that includes modifying my existing fuel modules so my fuel return from the FASS and VP/INJ all go back into the fuel basket. I had to cut out a couple of the old stock lines to eliminate some unnecessary parts, but now it's extra short and I think may be causing my 'hard start' issue.
Problem is, it seems that when my fuel level gets below a 1/2 tank, I start having issues similar to having a leak in the return line, but I've fixed all those and problem is still there. So this is my last ditch attempt to fix this before I just say screw it and know that if I'm below 1/2 tank parked on a slight up hill for a while that my truck will crank a second or two longer then normal before starting.
