- Replies 38
- Views 7.5k
notlimah 18 posts
Mopar1973Man 5 posts
TFaoro 5 posts
Me78569 4 posts
It doesn't need to be warm to do injectors! Run the engine until it gets to about 140*, then swap everything! It'll keep your hands warm while working on it and it'll start much easier than it
I would also suggest getting the old Sniffer involved.
Be careful sniffing, apparently it's cause of cancer and liberals don't want you sniffing it, because you never know if what you're sniffing is good for you. I'm sure some day they'll tell us all how
So I've been noticing that here and there my truck will put out a good amount of white smoke when starting up cold. This morning it did it for maybe a minute, tops, but went away after that. The truck had sat since Friday through some 30ish degree weather and I plugged it in on a timer so it'd be on a few hours this morning. Also used grid heaters and still had smoke. It doesn't do this any other time through out the day, but it also doesn't do it on every cold start in the morning so sort of weird and inconsistent.
What do you think? Anything to worry about or sound normal?
