- Replies 20
- Views 6.6k
Cwhatevr02 7 posts
Mopar1973Man 3 posts
dripley 2 posts
NightHawk 2 posts
Usually best to have thew entire donor truck present so you can raid any parts, wiring, or modules as required.
I wonder if it might have something to do with the 02 auto truck having the vacuum assisted cruise versus the 02 manual being fly by wire. Which system are you using now?
Both PCM and ECM would have to be change to for manual with fly by wire cruise. Being the PCM is the cruise control module and the ECM is getting the throttle from the PCM not the APPS. So the softwar
Hi there,,,I'm a newbie,retired GM technician and frustrated Dodge lover. Recently I did the "easy" conversion from auto 47RE to a brand new NV4500 with upgraded Southbend clutch. My truck is a 2002 2500 4X4 SRW 24V with 110K miles,FASS150,RV275 injectors,Fleece Cheetah turbo,Banks air and intake. The conversion went relatively smooth besides some minor electrical glitches. I used all new hard parts along with a new PCM for a manual truck with my VIN programmed to it and Smarty programmed the ECM. It might be relevant to say that I had replaced my APPS unit ($Mopar) several months prior to doing the conversion because of failure codes,no pedal issues. Now,,,,,The conversion is 99% done and I love it but,,,I am left with a " Steady" cruise light on and a surge/hesitation at steady low rpm speeds. I have 2 new batteries,very clean cables and have triple checked all of the grounds. I don't see any voltage spikes from the APPS with my scanner while duplicating issue. Do I ultimately need to replace my ECM and engine wiring harness or am I missing something???,,,Please help,,,lol Thanks Y'all
