Is 2 micron small enough to pass thru fuel system
- Replies 16
- Views 4.8k
Mopar1973Man 5 posts
015point9 3 posts
Wild and Free 2 posts
AH64ID 2 posts
Popular Days
Some folks have lost the size comparison to microns. So as a refresher...
IIRC the factory filter for 00+ got bumped to a 7um filter. Personally 10um isn't enough, even if there are 2 of them.
You are correct, anything bought through a dealer is a 7UM fleet guard packaged as Chrysler part. I think most now cross over automatically to the 7 micron but it never hurts to check and ask.
I drained my fuel from my fuel tank into 5 gallon buckets because I needed to fix leaky sump and mount Airdog pump in better spot. When I got ready to pure fuel back in noticed rather large beads of whatever (water, dirt, etc) mixed in with fuel. Finding micron sizing stuff on line, I ran fuel thru coffee filters (supposed to be around 20 microns). The fuel still didn’t look good to me. I then removed Airdog pump from truck and hung it in the fence and with long wires and a remote 12 volt switch and have been running fuel thru the Airdog filters. Airdog says one if its filters is 2 micron. I believe that filter is the one with a water drain valve. Fuel now looks “clean” to me. I was going to throw away about 25 gallons just to be 100% safe. But local auto part store recycle tank is full and has been for over 2 weeks. Wife gets upset with me when I pure out along fence. And surprising fuel doesn’t control weeds as much as I thought it would.
So…Is there anything less than 2 micron is size that could mess up injectors or VP pump or anywhere else in fuel system?
