Quadzilla Adrenaline Economy and MPG
Since @Me78569 and company have the tuning thread for performance side. I'm going to start the ecomony and MPG thread for the Quadzilla Adrenaline. I'll be posting up my MPG logs and all data I can provide of what I've got going on. I've been keeping hand math logs of all fuel purchased as well as my tablet running OBDII link LX and data logging from that direction too. I'll share my tunes and settings as well.
QUADZILLA TUNES CURRENTLY LOADED (Check back often file is updated at random times)
Quadzilla Ardrenaline.xlsx
  • Replies 431
  • Views 157.9k
    Finally!!! Yeah!   Broke 21.06 MPG. Finally got the tuning figured out. 297 miles and filled up with 14.096 gallons giving me 21.06 MPG. This is still with winterized #2 diesel and winter co
    I've learned a lot so far.    Light Throttle Load Limit (Percent) - Mopar1973Man Suggested Setting 25%   This value should be built around the 65 MPH speed on flat ground. That is
    Now that I've returned to the wiretapped crowd now I can see the difference between CANBus only o Wiretap. Of course, the power is way better tapped but I want to find out if I can reach higher like I
I bought my comp about 6 months or so before this I quad thing cam around. So I guess I will be comping a while longer.
18 minutes ago, Me78569 said:
if it aint broke dont fix it.
Thats exactly why I'm rather reluctant to buy one..my EJWA works fine lol. But for what I want to do with my truck, Apparently its going to help.
Bigger your injectors are the more you need the control of the Quad.
Just the fact that you can tune it less than factory and make it smoke free and then have all the power when you want is priceless and valet mode is great too for more than one reason, too much to list. Once all the bugs are ironed out and we all get a hang of it, then......makes me want to hug my truck even more now. I know that's wrong.
hopefully the bugs are ironed out haha, I dont want to change anything else.  Now we are just figuring out who things work with the ECM and our trucks.
:lmao: you think we're done!? There is much work to be done! :stirthepot:
I'll start driving the truck again and complaining.... don't tempt me.
But because this is a MPG thread, I hope to be posting some numbers soon. Hopefully the I can get my boost cruise setting figured out for higher speeds. I'm thinking 20ish psi, but we'll see.
I'm almost of the opinion that you need a special tune for interstate travel to do it right. Because in the lower speeds of the city the cruise timing hang up to easy being you push the cruise timing pressure so high. Like my typically 55-65 MPH highway stuff I could set the cruise pressure for 8-10 easy. Interstate I need 15-18 PSI to keep the cruise state.
You may be right about that. I can't think of a parameter we could use to base off of that would work for both though.
I've been thinking about it too. The problem is the types of driving you do. City needs a tune to itself (0-45 MPH), then highway (55-65 MPH) gets a tune, then interstate (75-85 MPH) gets a tune. Because if you think about the different conditions and what you got to do timing, fuel maps, etc. All need a bit a pulling one way or another to make the driver happy. Like in the city you want your 1500 timing a bit lower to help spool up and get launched from light to light maybe even throw in fuel load timing on 2-3* just to aid in that. Highway you can crank up more timing building on the 1,600 to 2,000 RPM range. Then when you get to the interstate and you twisting 2,100 to 2,400 RPM constantly with boost riding in the 10-15 PSI range makes for rather challenging tuning.
As you start getting to a science for mpg you are right, you would need a tune for each situation.  It would be nearly impossible to tune the truck perfect for all situations regardless of the platform.  The question most of us have to ask is if there is a big enough reason to justify that?   For you it might be, for me not so much haha.
For myself I normally drive 55 or 60 everywhere regardless so one tune works fine.  Sometimes I do 75 but it is so rare that I don't really see a need for tuning time on that.
Appears like the 17 degree timing is working way better for MPGs compared to the 20.5 degrees I was running previously. I'm at 323 miles at half tank. I'll calc and calibrate at the next fill on the way home. More to come...
that's very interesting.    My truck absolutely likes 19*-20* of timing at 65.  maybe I should drop that timing down and see what she does haha.
I was seeing over 24mpg at 65mph with 19*
I think it has to do with injector size that making the difference I've got smaller nozzles than you So you require more timing to light off the bigger droplets. You might knock 0.5 or 1 degree off the cruise timing and see what happens.
yep I will try that the next long trip I take
Until then I am going to enjoy my new springs and studs :burnout:
:shifty: of course after a week of heat cycles and a retorque.
Like myself my majority is 65 MPH highways so I'm going to build on the 65 MPH and use the Truck lane for interstate and old to 70 MPH which is Truck speed limit. This will make it easier to build my economy tune.
Just for fun today since I'm at home I had to make a quick trip to McCall, ID. So I went for the full hypermiling again like I use to and turned a 20.3 MPG for the day. Mostly highway travel. I'll be heading out for my long haul tomorrow and finish this tank of fuel out.
