stumble on acceleration
- Replies 47
- Views 17k
Thunder2001 14 posts
Me78569 8 posts
dripley 5 posts
Dieselfuture 5 posts
The lift pump does not have a relay. The fuel relay in the PDC is for the VP.
Honestly I think most of the VP44 failures were related to the actual deisgn of the vp rather than input fuel shortcomings. Things like -non-leaded soldier coming into play -ba
@TFaoro had 2 or 3 bad bluechip vp's out of the box so odds aren't that low. I am assuming you used a good code scanner to scan for codes? I don't think the harness is bad load shouldn't play into
motor stumbles when under slightest load. slow acceleration no problem. video attached explaining everything that has been replaced and tested
