Protect your lift pump
- Replies 57
- Views 19.6k
SilverMoose 10 posts
Mopar1973Man 9 posts
2001cummins 8 posts
klcammie 7 posts
16 gauge wire will handle 20 amps up to 10'. The relay should be at least twice the amp draw of the motor (20-40 amps). If your fuel pump motor draw 10 amps at start up then the minimum relay will b
I've posted an article in the 24 valve 2ed generation fuel section titled "Installing Protective Lift Pump Relay". This should help explain why a relay is needed and how to install it.
@klcammie I am by no means trying to hijack your thread as I got a relay installed for the LP yesterday. It was a pretty straight forward task. The longest part is making the wire harness to connec
Thank you. Your message about wiring a relay in the circuit for the lift pump saved my ecm. Yesterday I lost fuel pressure and the auto reset breaker got so hot it stuck in the on position. I couldn't hold it in my hand. I can't imagine what this would have done to the ECM. IMHO all should wire a relay in the circuit to the lift pump. Thanks again.
Edited by klcammie
