- Replies 47
- Views 9.5k
abner99 14 posts
notlimah 8 posts
SilverMoose 6 posts
Mopar1973Man 4 posts
The return is bleeding pressure off to the tank. Decrease that flow and more goes into the supply. That equals great supply pressure.
Sounds like me trying to explain to my wife anything about automobile.
But reading those posts on fb are fun! Especially when you're the only one saying something different and you're right lmao
So I did a boost leak test on my 99 cummins found a t clamp that needed to be tighted. Took the tester to 25 psi. The gauge is slowly going down like .5psi every couple second. Did the soapy water test can't find anything. Can't hear anything. Is this normal to loose psi with it pressured up or should it stay at 25psi.
