- Replies 25
- Views 6.1k
Mopar1973Man 7 posts
dripley 6 posts
JAG1 4 posts
notlimah 4 posts
I will quote again from the ASTM testing labs... There is no benefit to using a higher cetane number fuel than is specified by the engine's manufacturer. The ASTM Standard Specification fo
Ummm... EGR all you doing is flooding the air mixture with CO2. Everyone is so wrap up with cold air having denser charge of oxygen but then accept the idea of EGR pump exhaust gases and CO2 back in t
That was oil from from the leaking front engine seal. If you would come by you could help me fix them.
What are yalls opinions on opti lube I have been using it and seems to smooth out idle and motor seems to run better than with just the 2 stroke oil I have run in the past. It is little expensive but has better lubricity results from past studies
