Removing Crankcase Vent for Valve Adjustment?
- Replies 9
- Views 2.5k
Mopar1973Man 2 posts
sooxies 2 posts
Dieselfuture 1 post
TFaoro 1 post
Popular Days
He has to have the 12v style tappet cover vent. He's trying to remove it so he knows when the engine is at TDC and adjust the valves.
I have the vent on mine. The po had siliconed it up good. Iirc I used a strap wrench to get it loose. You have to unscrew it about a quarter turn, assuming the plug is same as vent.
Typically grab it with my hand and twist it off towards the left. I've only used a strap wrench once to remove a vent. Now you never want to put anything in the hose neck to twist it loose. It will br
I've seen to run across another normally simple task that is giving me headaches
Are there any tips or tricks to removing the crankcase vent on the timing cover? My vehicle has the plug (12) and not the actual vent (20) with the puke bottle. Being thin, it is quite difficult to grab onto and it just wont move at all. I see there is an o-ring that goes along with it. Are these notorious for being difficult to remove?
