New guy needing help truck down
- Replies 13
- Views 3k
Notch86 6 posts
Me78569 2 posts
Mopar1973Man 1 post
notlimah 1 post
Ordered it from auto module source
verify none of your 5v reference sensors are shorting to ground.
First read over the diagnostics of each code. There is only 1 ground wire to worry about. The rest of the grounds are subsystems like lights. Have you tested for excessive AC noise?
I have a 2001 Cummins 4x4 6-speed the truck starts and idles fine but I'm getting several codes and have dead pedal and the rpm on the tach drops to zero at idle
The codes are
P0122
P0238
P0341
P1689
What I've done so far is
Replaced apps with a timbo
Replaced map sensor
Replaced cam sensor
Cleaned every ground I can find
I'm really now sure where to look from here
Thanks for any help in advance
