- Replies 24
- Views 4.2k
Rob lint 10 posts
dripley 5 posts
Mopar1973Man 4 posts
Dieselfuture 2 posts
Popular Days
I finally replaced Injection pump. I used the instructions supplied from this site. The truck hasn't run this good in about a year. Thanks for all of the help.
Before you wear the starter out trying. I've ran into some like this. Just unhook your grid heater trigger wire (one off of each relay). Then with the turbo face exposed get one person cranking and th
This is my first post to this forum. I have 98 24valve that had a fuel leak on top of the fuel filter heater. I fixed the fuel leak, reprimed the filter and fired for two seconds then died. I cracked the injector lines to get the air out of the lines and have fuel to all of the injectors. The truck will still not fire, acts like it wants to start but won't. I have good fuel pressure to the pump and no codes until switching relays. Codes 1688 and 1689 came up only after playing with relays. Any help would be appreciated.
