- Replies 25
- Views 6.7k
TFaoro 8 posts
Mopar1973Man 7 posts
jlbayes 4 posts
notlimah 3 posts
By then he'll probably have a jet engine in there
I will be back on Friday
Why? Because it might break or the fuel mileage sucks that bad or both? I though you owned a Cummins not a Ford?
So my grid heater ALWAYS comes on when I start the truck. It doesn't matter whether the engine is warm, ambient is warm, etc.
Example today:
78* ambient temp
Engine temp 180
Intake air temp 175
Charging voltage (once moving and grids shut off) 13.6V.
The lower charging tells me the battery temp sensor knows it's warm out, so that's pretty much ruled out. Is the ECM just mad because it can't see a VP??
